Hi All,
Please be gentle, it's my birthday today and I'm not getting any younger. :|
A few years back I bought something very similar to this for my 6040 CNC:
https://www.aliexpress.com/item/CNC-...357810440.html
I have never used it (it's probably crap right?), and the other day I got to thinking maybe it could be the basis of a simple T-Slot CNC lathe, and then I had some beers at lunch and ordered the below items from aliexpress (birthday presents)... oops!
So my thought process was:
Get rid of the stepper on the 4th axis and replace it with a speed controlled motor:
https://www.aliexpress.com/item/90ST...844070107.html
And use this system (X 600mm & Y 1000mm) to move the apron? and tool holder?:
https://www.aliexpress.com/item/FLS4...854896491.html
Bolt it all to some "bolted together" extrusion like this:
https://www.inventables.com/technolo...m-x-80mm-clear
Bolt the extrusion to a bench.
Voila, a CNC lathe.
I'm a "IT nerd" beginner with no real lathe experience, I haven't really got a use case for it, it was more of a DIY tinkering project (I have LOTS of projects in the "queue").
I realise I have probably messed up here quite a bit (no doubt I could reuse the parts in other "projects"), I will probably have all sorts of issues with accuracy but how bad is it (I would really appreciate a kind of A-Team/MacGyver "stuck in a barn with bad guys outside and need to build a CNC lathe with these parts to help save us" mentality)?
Thanks.
Richard
