Hi!
I'm planning on buying the G540 4-Axis Digital Step Drive for my CNCEst 6040 as I'm told this is pretty much the best controller I can get for a reasonable amount and it will make a huge improvement.
I have a few questions about this and hope someone can shed some light on what I need.
- The power supply in the original controller is Input 220VAC Output 24V / 6.5A, I've read that I should go for a 48 Volt supply. If so, which should I buy?
- I have different connectors on my motors than the serial looking cable the Gecko drive uses, are these drives compatible?.
- I have read in several places that I can connect the Spindle VFD to the gecko and control it through Mach3, but I have not found any guides on how to do this either, are there any (I asked this question directly to Geckodrive but they did not respond)?
- I have yet to find any guide on how to remove the current controller parts and install the Gecko instead are there any such videos or guides?
- Is there anything I have not mentioned above which I should know or get, this is my first CNC so I might be missing something obvious here.
I've included some pictures which might help fill in more details.
Thank you very much for any help!
