I have an Output/Fuse Failure in APC Rack 2 alarm, remedy says to check for over temp, the machine has been down for a day so this is not an issue. or current overload, I have disconnected all of the outputs from rack 2 and the 24vdc supply from the smart brick then restarted the machine I would have guessed that a different alarm would have occurred. has anyone had this issue?
thank you
