Originally Posted by
Levibad1
Hello. First post here. I currently have a series 2 special with 2 axis dro and x-axis power feed. I really never planned on a cnc knee mill, but my place of work had a charity auction and i purchased what I was told was a complete running kit that was removed from a regular series 2 machine to upgrade to a newer kit. From what i was told the only known issue was that the start button on the control was somewhat finicky. I didnt realize this was being auctioned off until it was almost over and pulled the trigger with out much research. I am looking for some input.
1. I think this should be a direct bolt on for my machine since the series 2 and series 2 special are basically the same from the column down. Is it a direct bolt on?
2. From the pictures attached, did i get all the major components that i couldnt easily and cheaply replace?
3. I wasnt really in the market for a cnc. Is this fairly user freindly? I haven't touch a cnc control in 15 years.
4. Finally, what is this worth (assuming its complete and works)? Hoping i didnt over spend even if it was for charity...
