As an endmill enters a cut (particularly as it moves around the final pass on the outer profile of a part it flexes a little away from the part. then as the tool completes the cut all the way around and moves away from the part it tends to leave a little mark that is visible and can be felt. I think it might be called a registration mark.
On a recent batch of outsourced parts I noticed this blemish was fairly distinct, enough to feel the bump with a finger nail. The problem is the face the mark is on is the worst location it could be because that face is a heat transfer face in the assembly, meaning I want that face to fit tightly against its mating surface. Any imperfection on that face might reduce heat transfer. And just as easily the tool could have started on a different face.
I am already reving my drawing so I want to put something in to tell the MFGr to not leave those marks on that face. What is the best way to do this?
I am leaning toward a 125 micro finish. I don't want them to grind that surface or get too caught up in perfection. I just don't want any machine marks there.
