585,977 active members*
4,126 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > What do you can the mark left by an endmill and how to disallow it in my drawing
Results 1 to 2 of 2
    Nov 2009
    As an endmill enters a cut (particularly as it moves around the final pass on the outer profile of a part it flexes a little away from the part. then as the tool completes the cut all the way around and moves away from the part it tends to leave a little mark that is visible and can be felt. I think it might be called a registration mark.
    On a recent batch of outsourced parts I noticed this blemish was fairly distinct, enough to feel the bump with a finger nail. The problem is the face the mark is on is the worst location it could be because that face is a heat transfer face in the assembly, meaning I want that face to fit tightly against its mating surface. Any imperfection on that face might reduce heat transfer. And just as easily the tool could have started on a different face.
    I am already reving my drawing so I want to put something in to tell the MFGr to not leave those marks on that face. What is the best way to do this?
    I am leaning toward a 125 micro finish. I don't want them to grind that surface or get too caught up in perfection. I just don't want any machine marks there.
    Dec 2015
    15
    Re: What do you can the mark left by an endmill and how to disallow it in my drawing
    First off, you can add about any note on the drawing you like. So that's up to you.
    Also, this can be averted by using circular path entrance and exit. Or, as easily, keep cutting until you get to an outside corner. Altogether too often, programmers just "take the path of least resistance" and do whatever the computer comes up with. This is one of those results that, like you say, might not matter, but sometimes it does. Depends on how much of the process you have control of or can recommend it might be cured without a drawing rev and simply a tape edit.
    I have placed shadow profiles of cutters on hogout parts to show how to cut the area in question. This is completely allowable (at least in aerospace).
    In ANSI Y14 you can declare a Coplanar feature callout. Or, you can declare the surface a Datum and declare the feature within the limits of the datum that you like. This way, you needn't require a mirror finish to the machining, but can hold them to a flat (or straight) surface without any bumps.
  1. sodick mark 25 controler mark 21 sys disks
    By graydog68 in forum EDM Discussion General Topics
    Last Post: 05-22-2018, 05:54 AM
  2. Replies: 13
    Last Post: 03-30-2018, 04:30 AM
  3. Replies: 1
    Last Post: 04-02-2016, 12:56 AM
  4. new drawing board --wicked size 44x60 drawing area
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 02-08-2015, 12:58 AM
  5. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
