585,997 active members*
5,082 visitors online*
    May 2018
    6
    syntec 900M controller
    anyone know the M code for air blow in syntec??
    M8 for coolant
    M7 for collant through spindle
    Jan 2012
    36
    Re: syntec 900M controller
    Hi ali789,
    Don't quote me on this but I believe machine builders can assign them, sometimes even during setup of the machine. I would think they have a specific one they like to use but it could be a different M code on two of the same machines. It would probably be best to call the machine manufacturer. There does seem to be a lot of post guys reading these threads so they may have your answer off the top of their heads or at least can give you a couple to try. I'll keep checking.
    Darrin - SolidCAM
    Jan 2018
    38
    That information is correct. The machine builder / end user can customize the M-codes to their preference. Usually builders will follow Fanuc standards, but it is not always the case. If you can find what Output relay is controlling the air blow you can find it by looking at the ladder of the control.
  1. Difference between Syntec 6MB controller and NK 300 Controller
    By hunnyk in forum Centroid CNC Control Products
    Last Post: 12-23-2017, 05:38 AM
  2. Help : Solidcam and Syntec 900M Controller
    By dungbt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-13-2015, 09:05 PM
