585,906 active members*
3,652 visitors online*
    Aug 2018
    29
    ISEL stepper question
    Still in the evaluation stage trying to figure out if I can get what I have working and the best way to go about it.
    Once you have the housing off the steppers you have 10 wire coming out of mtr + a ground.
    There are 8 wires that pair up to 4 pins in the connector. Does this indicate a 5 phase stepper?
    Would I be better off just replacing these with a NEMA 34 midrange torque mtr?
    Thanks for any help
    cncneon
    Dec 2017
    82
    Re: ISEL stepper question
    Just you need these 8 wires that you mention.
    in each pair dont use the white color wire and use another wire in that pair.
    then you will have stepper with only 4 wires and you can connect it regularly.
  1. techno isel davinci stepper cnc series 0808
    By grebber in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2015, 08:05 PM
  2. techno isel davinci stepper model 0808
    By grebber in forum Uncategorised MetalWorking Machines
    Last Post: 04-15-2015, 03:14 PM
  3. Wiring breakout board to old Isel Stepper drivers
    By TashadraCPT in forum Stepper Motors / Drives
    Last Post: 08-29-2012, 06:40 PM
  4. Isel Stepper Controller and Motor with mach3
    By jamesbond007 in forum Techno CNC
    Last Post: 07-24-2012, 03:22 PM
  5. isel ballscrew question
    By rzmac in forum Benchtop Machines
    Last Post: 02-07-2012, 11:51 PM
