I am working on a prototype that requires a single-axis servo system with very high accuracy. I don't need a lot of power or torque, the servo will turn a relatively light object just several degrees. I looked online but I couldn't find many options. Maybe I am not searching correctly. The application is very sensitive to vibrations so I cannot use a stepper.
Could someone suggest a brand/model or simply point me in the right direction?
These are the requirements:
- Brushless
- Low voltage
- The drive should be able to work with Pulse(Step)/Direction signals
- Very high PPR
In previous discussions in this forum, I've read about motors (encoders) with 40000PPR or even more, however, I couldn't find even one.
The closest thing I found so far are these:
ACM601V36-T
ACS806
Could you recommend a better alternative?
