585,712 active members*
3,935 visitors online*
    Nov 2005
    222
    Sieg X3 conversion post build.
    Well I finally finished the conversion of my X3. I'm down to the finishing touches. For the mechanics I used the CNC Fusion Deluxe kit with custom length screws for increased travel over the stock mill. For the electronics I used Gecko 203V drives powered by a Automation Technologies KL-4820 non-regulated power supply for the 48volt and a Meanwell 24 volt supply for field power. I used a Mesa 6i25+7i76 Plug-N-Go kit for the BOB. I also upgraded the spindle to a DMM Technologies DYN4 1.8kw servo as a spindle motor geared 1:1.8 for a top spindle speed of 5400. Everything in the control cabinet is running on 240 volts. For software LinuxCNC. I also built a counter balance based on what I had seen done on other peoples build. The control cabinet was a bit of work but I got a lot of help from other members on this and the LinuxCNC sites. I am very happy with how it turned out and surprised how well it works without going all the way to flood coolant. I'm just using air at this point and I usually cut aluminum using carbide three flute endmills at 5200 RPM. I use Fusion 360 for my CAD/CAM. I'm not doing production work just hobby use.
    John
    Sep 2016
    7
    Re: Sieg X3 conversion post build.
    Looking good rcheli :cheers:. I do have to know what DRO are you using?
    rngr1
    Nov 2005
    222
    It is a SchumaTech. It is/was an OpenDRO project that came in a kit. Home Page | shumatech.com. I'm not sure if you can still get the kits. I am using Jenix glass scales that I got from "Linear Measuring Systems Company" (Tim Barnard - [email protected]). I have the same DRO on my lathe and mill. Now that I have my mill converted to CNC I don't really need the DRO but it is handy when I doing something manual via the pendant. The DRO also supports digital caliper type scales.
    John
    Jul 2017
    18
    Quote Originally Posted by rcheli View Post
    John
    Nice build!
    Wish the OpenDRO project was getting much love,furthermore as TouchDRO doesn't seem to be as open as it has been.
    Envoyé de mon ONEPLUS A5010 en utilisant Tapatalk
    Nov 2005
    222
    Thanks silopolis.
    With what I have learned by building the DRO-550 kit and playing with an Arduino I think it wouldn't be that hard build a DRO.
  1. Sieg X2 CNC conversion
    By Nixx123 in forum Benchtop Machines
    Last Post: 08-17-2015, 01:27 PM
  2. Another Sieg X2 CNC conversion
    By eldata in forum Benchtop Machines
    Last Post: 12-19-2014, 01:52 AM
  3. sieg x2 conversion
    By Saxdorff in forum Benchtop Machines
    Last Post: 12-09-2014, 10:01 AM
  4. Build Thread - Sieg X2 CNC Conversion
    By Cret in forum Benchtop Machines
    Last Post: 09-03-2014, 12:39 AM
  5. Sieg X2 CNC Conversion
    By cowana in forum Benchtop Machines
    Last Post: 10-29-2011, 06:31 PM
