585,992 active members*
5,238 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > "RUN FROM HERE" Z- Axis goes to Limit switch???????
Results 1 to 7 of 7
    Jun 2009
    110
    Question "RUN FROM HERE" Z- Axis goes to Limit switch???????
    Sometimes when I need to stop a cut file for some random reason I restart using the "Run from here function". When I hit "Cycle Start", the Z will travel all the way up and hit the upper limit switch. My clearance plane is set at 0.250. Can anybody guess why RhinoCam wants to do this? What am I doing wrong in Parameters to be causing this.
    Thanks in advance
    Steve in Maine
    Oct 2005
    169
    Re: "RUN FROM HERE" Z- Axis goes to Limit switch???????
    I don't think that has to do with RhinoCam. Sounds to me like you need to do something different in the control. What machine and control are you running?
    Pretty unlikely that it's RhinoCAM, as it wouldn't know where you were doing a Run From Here.
    It's most likely the control software doing it. You didn't say which one you are using.
    Jun 2009
    110
    Sorry for lack of data. Running Mach 3 like the rest of the world. DIY unit but basically a copy of K2cnc unit.
    How do you have Safe Z set up in Config > Safe Z?
    Jun 2009
    110
    I have NO idea? I did not realize there was a SAFE Z function in Config. Let me take a look and get back to you on that. Thank you for the direction. Sounds like this will solve my problem.
    Steve in Maine
    Jun 2009
    110
    SOLVED!!!!!!! It was the SAFE "Z" settings. I never set them. Working great
    Thanks for the help!!
  1. "RUN FROM HERE" Z- Axis goes to Limit switch???????
    By Barefootboy4 in forum Mach Lathe
    Last Post: 08-13-2019, 01:15 PM
  2. Location of "x" axis overtravel limit switch on Arrow 500
    By Joe Miranda in forum Cincinnati CNC
    Last Post: 04-20-2015, 03:56 PM
  3. "limit switch triggered" aleatorio en Mach3, Ruido?
    By lamartinada in forum Spanish
    Last Post: 11-20-2013, 07:28 PM
  4. Replies: 3
    Last Post: 09-30-2013, 08:55 AM
  5. "Test this axis/Run", and a limit switch
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 01-31-2010, 12:08 PM
