Hi all!
I am new to this forum and machining as well. I am purchasing a new milling machine from china whose specifications are :
Description Parameter
X Y Z working area 600*600*200mm
Table surface T-slot Work table
Frame Cast steel
Z structure Ball screw
Max. Rapid Travel Rate 6000mm/min
Max. Working Speed 4000mm/min
Spindle Power Motor 2.2 kw spindle
Engraving Speed 0-4000mm/min
Spindle Speed 0-24000RPM
Drive Motors Imported Japan Yaskawa Servo Motor and Driver
Working Voltage AC220V/50/60Hz
Operating System WEIHONG NK 260 Constrol System
Interface USB
Flash Memory 128M( U Disk)
X,Y Resolution <0.01mm
Software Compatibility Type3 software, Ucancam software (Option: Artcam sofa
Net Weight 600KG
Gross Weight 700KG
2.2 KW Spindle
Please help me choose the controller! I will be very grateful to you
