502,649 active members
6,853 visitors online
Results 1 to 1 of 1
    Junior Member
    Jul 2018
    ps error 128 trying to DNC
    I have a milling center with a Fanuc O-MD control and I'm having problems to DNC run a program from the computer.
    I select MEM-DNC and press the Cycle Start key and I get LSK flashing in the lower right corner of the screen.
    When I start transmitting from the computer, the first two lines go through and then I get a ps 128 alarm. First line is of code is the % character.
    From the OFFSETS screen pressing the OUTPUT-START key I get all the data sent correctly to the computer, so I assume cable and RS2332 parameters are correct.
    Is this assumption correct?
    Any ideas?
    Please
    Member
    May 2016
    342
    Re: ps error 128 trying to DNC
    What happens when you load a program to the memory without dnc
