Good day,
Can't figure out how to save good axis positions.
When i reset XY axis they shows 0, but when i turn off/on machine position became again 10000
Attachment 401426
MB - RDLC-V5.00.32
will be thankful for any solution !
Good day,
Attachment 401426
MB - RDLC-V5.00.32
The way I do it is when I move the head to a spot where I want it I just make a small dot or line and lower the power to zero the run that file once the next time the machine will go to the position you want. My machine always resets to the last position that I started a file from
My problem is, that i cant press RESET button laser head - hitting to limit sensors and doesn't stops. If I reset axis one by one than ok, unit next off/on machine... again positions 10000... and cant setup "HOME"
I removed function "Home", so when machines turns on - head wont move, unit i'll move it.
