pls, how to use " tool retract in case of load monitor overload " ?
hello, did anyone used #6.4 tool retract cycle request at overload, or #44.4 tool retraction cycle at detection of overload in load motor (L side of parallel two-spindle machine)?
now i have some drills, and it would be nice to know that Zaxis is moving backwards each time overload is reached
but how does the control now which axis to reverse ? is it possible to choose which axis to reverse ? and is it possible to check this behaviour ?
about #6.4 there is a bit of confusion : manual says that 0 = valid, while inside parameters, 0 = invalid; pls check attached
kindly
