if #33.3=1, is possible to use CALL O+16chars; pls check attached
for example CALL OOOOOHOOOHOOOHOOO / OWHATISTHIS / WHEREISTHEDRILL / OMFG etc
Hi deadlykitten, there is also on P300M?
Inviato dal mio SM-G950F utilizzando Tapatalk
hello okuma85, i just checked on the mill, and #33.3 seems to be there for something else
maybe you will find some patience & time, so to scroll through all those bits on the mill
if you wish, i will search on my control
also, inside lathe manuals, there is nothing at #33.3; pls check attached
i found that setting by mistake, while i was looking for something else
do you really need such long names ? i always believed that you are a 16+chars kind of person / kindly
