585,908 active members*
3,879 visitors online*
IndustryArena Forum > CAM Software > Vectric > 5 axis cam software recommendat
    I’m just about finished with upgrading a 2003 AXYZ 4008 with a CSMIO/IP-S – 6 Axis Ethernet Motion Controller. I will use MACH 4 for control software. I need to purchase a cam software and leaning to Vectric Aspire. My question is will Aspire generate 5 axis code if I decide to add the 5th axis rotation axis. Any suggestions with any part of my project?
    Apr 2004
    5737
    Re: 5 axis cam software recommendat
    I don't think so. Vectric Aspire is pretty good for low 3D relief carving, such as signage. It has a way of "wrapping" a relief carving around an axis parallel to X, substituting A (rotary) axis moves in degrees for Y axis moves in linear units, so you can make 4-axis carvings that are basically cylindrical. But I don't think it has any way of dealing with a 5th axis. You might take a look at DeskProto's Multi-Axis edition, which can create true 4-axis toolpaths and lets you index on the 5th axis. But if you want live 5-axis machining, be prepared to spend a lot more.
    Andrew Werby
    Website
    Oct 2017
    49
    Fusion 360 just released a new pricing scheme and its much cheaper to get 5 axis capabilities.
    A rotary axis is 4 axis, not 5.
    Aspire can create "wrapped" code for a rotary axis.
  1. 3 Axis CNC Mill Software for PC - Checking Axis Movement
    By rickwoz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-05-2015, 04:06 AM
  2. 5 axis cnc versus 5 axis cam software
    By davidsutton in forum Uncategorised CAM Discussion
    Last Post: 05-24-2014, 06:05 PM
  3. 4-axis software?
    By saltytri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-18-2009, 06:36 PM
  4. 5 axis software
    By slpd in forum Uncategorised CAM Discussion
    Last Post: 08-03-2003, 02:57 AM
