585,733 active members*
5,061 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How can I enlarge a pulley center hole?
    May 2006
    309
    What is the best way to make a center hole in a pulley larger in order to fit a spindle? Will it be absolutely neccesary to get it perfectly centered in order to avoid any vibration at speeds up to 10 000 rpm?
    Jun 2010
    4256
    Re: How can I enlarge a pulley center hole?
    That is very, very hard to do well.
    Step 1: make mandrel which is a snug fit in pulley, mount pulley on it tightly
    Step 2: with mandrel in lathe, turn down rim of pulley slightly: circumference AND face
    Step 3: mount pulley by itself in chuck using rim and face - and clock it up anyhow
    Step 4: bore out slowly
    Note that all steps must be done very carefully on a good lathe if you want to spin it at high speed later.
    Cheers
    Roger
    Jun 2004
    6618
    I would think since you asked "Will it be absolutely necessary to get it perfectly centered in order to avoid any vibration at speeds up to 10 000 rpm?" that you will be better off buying the correct size. At that speed, it all needs to be perfectly concentric and balanced to operate correctly. Safety is also a real concern on pulleys at that speed.
    Lee
    Jun 2010
    4256
    Lee has a very good point: it needs to be centred AND balanced, for 10k.
    Cheers
    Roger
  1. Find center of hole
    By SPRSkip in forum Tormach PathPilot™
    Last Post: 07-05-2015, 04:22 PM
  2. Milling a hole - start the EM in center of hole
    By mkhushf in forum BobCad-Cam
    Last Post: 05-20-2015, 03:27 PM
  3. Oversized Pulley Bore Hole
    By JustinLiang in forum Mechanical Calculations/Engineering Design
    Last Post: 12-06-2013, 10:55 AM
  4. enlarge a threded hole in hard part
    By Kevin Taylor in forum MetalWork Discussion
    Last Post: 03-18-2011, 06:53 AM
  5. finding center of a hole
    By BeerFizz in forum Mach Mill
    Last Post: 06-15-2007, 01:17 AM
