585,962 active members*
4,037 visitors online*
IndustryArena Forum > CAM Software > Mastercam > vertify not working
    Mar 2008
    375
    vertify not working
    got this problem on mastercam cam for some reason when I do my toolpath I can see it on the backplot but when I go into the vertify I cant see the stock or even the tools
    is there a setting I have to turn on.
    have any of you guys had this problem and how can I fix it
    thank you
    Dec 2008
    3109
    Re: vertify not working
    on verify....
    there are on/off toggles on the upper toolbar for
    .. the toolpath
    .. the tool
    .. the stock remaining
    .. the original stock ... with a see through effect
    plus how the display moves whenn running ie tool stationary-stock moves or.. the reverse
    also (in "view") you can improve the display accuracy after zooming... there is a lot you can play with, try various combinations to what suits you best..... then do a "save as default" for when opening another verify session.
  1. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  2. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  4. how to add stock using the vertify
    By cob in forum Mastercam
    Last Post: 01-06-2009, 06:01 AM
