585,759 active members*
4,058 visitors online*
Results 1 to 2 of 2
    MK3/4 Axis Speed Issue
    I am rebuilding my CNC router controls with a MK3/4 and DQ542MA drivers. I have 2 ball screws on my main axis connected to axis 2 with 4 slaved. When I tested this setup, everything works fine.
    The X axis is connected to Axis 1 with the same settings. When I run it, the DRO looks correct but the movement is only a very small fraction of what it should be.
    The settings on all 3 drivers are the same, they are wired the same, and the axis steps/rev are the same.
    Can anyone point me in the right direction to troubleshoot this issue? Thanks!
    Mar 2017
    1304
    Re: MK3/4 Axis Speed Issue
  1. Replies: 3
    Last Post: 04-20-2019, 11:24 PM
  2. Replies: 2
    Last Post: 08-25-2017, 07:55 PM
  3. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  4. Issue with Mach 3 Speed when running 4 Axis
    By redneck_cues in forum Mach Mill
    Last Post: 11-30-2014, 02:11 AM
  5. Mach 3 Speed Issue on four axis foam cutting setup!!
    By Domdonder in forum CNC Wire Foam Cutter Machines
    Last Post: 04-01-2014, 02:02 PM
