585,737 active members*
4,798 visitors online*
    Sep 2018
    Shakes on the Y axis in 6040 CO2 laser machine
    Hello all,
    i have problem with chines laser machine 60x40 cm table it shake on Y axis.
    For now i check
    - belt tension / it is good, regulation does not change anything.
    - guides go smoothly, it does not seem that it was a mechanical problem
    co2
    I noticed that the problem is not constant in one part the oscillation is bigger elsewhere again it is small
    What i can check in next step?
    Oct 2015
    96
    Re: Shakes on the Y axis in 6040 CO2 laser machine
    Loose lens?
    Loose/vibrating one from mirror mountings?
    Polish @ Éire
    Sep 2018
    It's not that the mirrors and the lens are fixed rigidly.
    It work like this now.
    Apr 2016
    8
    it looks to be on both x and y axis- belt or screw drive? try setting to constant velocity mode and/or increase accceleration.
  1. Circles not round, 6040 laser machine
    By tigox in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-01-2020, 12:01 PM
  2. Rotary for 6040 laser engraving/cuting machine
    By lasertube in forum Commercial Laser
    Last Post: 03-28-2018, 09:58 PM
  3. CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2017, 12:53 PM
  4. 6040 Machine - Z axis gone?
    By _Kai_ in forum Chinese Machines
    Last Post: 07-05-2015, 12:59 AM
  5. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
