585,996 active members*
4,575 visitors online*
Page 1 of 3 123
Results 1 to 20 of 52
    ericks Guest
    Hertz spindles from Turkey
    Hi, i am going to order a spindle motor from this supplier soon. Just wondering if anyone in Australia would like to also order a unit. The shipping for 1-5 units is 150 euro(TNT express)....it makes sense to order more than one
    May 2005
    3920
    Re: Hertz spindles from Turkey
    Those prices are fairly cheap! I'm in the USA so I can't get into the buy party so best of luck with finding a partner.
    I must ask are you ordering directly from the manufacture or a reseller?
    ericks Guest
    I was unable to find a re-seller....Initially i planned to buy a Teknomotor but the one i wanted was over $1000 Aud
    Thanks.....i might buy a couple anyway, i am sure i will build another machine after this one
    Oct 2016
    128
    I have had 2 of these and Both of them broke on me. I used them to cut aluminum and they couldn’t handle it.
    ericks Guest
    Quote Originally Posted by dillonfitz View Post
    Oh no, may i ask how did they break?
    Oct 2016
    128
    Quote Originally Posted by ericks View Post
    I had an er20 model and er25. The er 25 actually spun the rotor on the shaft inside the motor. It was just press-fit on so it had no power after it spun. And the er 20 version worked for about 4 months then it finally just quit working. I think the windings burnt up but I’m not 100 percent sure. I switched to a used Colombo and never had another issue.
    Oct 2016
    128
    I did also use a gmt spindle with a delta drive , I never had an issue with that setup.
    ericks Guest
    Not good....i wish you replied this a bit earlier cause i ordered a couple of motors a few minutes ago
    Oct 2011
    33
    Do not worry, I have been used Herz spindle three years for now. I cut aluminium and Pom plastic . Spindle is HMB42d 24000 rpm with ceramic bearings.
    Oct 2016
    128
    They were great while they worked. The only thing was they were a little noisy. Sounds like a vacuum running. But for the price you can’t expect them to run forever.
    Oct 2016
    128
    The main problem probably was that the motor can’t handle the er25 collet. The larger tooling is just too hard on the motor.
    ericks Guest
    I see you even had the better model, the one with the steel in front....they told me to get this type for aluminium
    ericks Guest
    Quote Originally Posted by jannos View Post
    Thanks for the info....i bought a 2.0 Kw and a 1.5 Kw...both HMB120CK and both ER20
    ericks Guest
    Possibly....but why sell the motor with ER25 then??
    Oct 2016
    128
    That’s what I was thinking.
    ericks Guest
    My kress router spindle has been going for almost seven years. I cut aluminium, plastic, rubber, timber, brass etc.....but i must add that i never overheat or abuse my tools
    Oct 2016
    128
    I run real machines so Im guilty of being bit rough on my smaller home made machine.
    ericks Guest
    I can understand that....
    Oct 2016
    128
    But I still enjoy the aspect of building a machine and watching it run!
    Oct 2016
    128
    My first home made machine is what led to bigger machines as well.
Page 1 of 3 123
  1. Why are keling ATC spindles so much more expensive than er11 spindles?
    By sburck in forum Automation Technology Products
    Last Post: 12-20-2019, 02:32 PM
  2. Hertz spindles
    By Goemon in forum DIY CNC Router Table Machines
    Last Post: 10-24-2017, 05:44 PM
  3. Hertz Motor HMB42C bearing replacement
    By vakeiros in forum Spindles / VFD
    Last Post: 06-30-2016, 02:25 PM
  4. KMB1 motor frequency/hertz???
    By m_mcgranahan in forum HURCO
    Last Post: 02-22-2011, 12:26 AM
  5. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
