585,902 active members*
4,494 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > ER2 alarm on Fanuc controller O-T
Results 1 to 12 of 12
    Sep 2018
    5
    I can manually move axis but will not home it’s on a Fortune Lathe
    Re: ER2 alarm on Fanuc controller O-T
    Quote Originally Posted by Jd1928 View Post
    Whats the value of Parameter of 1815 APC and APZ
    Sep 2018
    5
    Quote Originally Posted by yoursrakesh View Post
    I don’t see 1815? I have seen it on newer controls this goes from 919 to 8100
    Sep 2018
    5
    I can’t clear the ER2,alarm on machine side I can jog X andZ manually I cannot move turret or spindle or home it
    Dec 2009
    952
    in your 0T controller ,theAPC and APZ are set in parameter 20 and 21,but in your case,if it is a Victor machine musy be something else,like lubrification or so.
    is the single block active?
    upload a photo of the operator panel.
    May 2016
    526
    Where is the alarm 2 showing ?
    On the drive or the screen ?
    Sep 2018
    5
    Quote Originally Posted by mbservice View Post
    I will send pic later it’s on lower section of main control pannell it has ER1 ER2 and ER3 and just red lights that luninate it has a red ER2 there are no alarms on any boards
    Dec 2009
    952
    is this your panel?looks like this?
    Sep 2018
    5
    Quote Originally Posted by zavateandu View Post
    No pic attached
    Sep 2020
    8
    Did u fix it ??
    Guys pls help me ???? my cnc lathe is victor vturn 16 and same pproblem
    Jul 2022
    6
    i have same problem, did someone resolve?
    Sep 2020
    7
    I have a similar problem with er2 it doesn't let me move the spindle in mdi, memory and jog, everything else works normally, can you help me?
  1. Replies: 1
    Last Post: 05-19-2015, 07:00 AM
  2. ATC Alarm on Fanuc Controller
    By bikebasher in forum Fanuc
    Last Post: 01-29-2013, 06:28 AM
  3. fanuc om controller alarm codes?
    By Twin-10s in forum Fanuc
    Last Post: 08-10-2009, 05:47 AM
  4. Fanuc 18i controller 926 FSSB alarm
    By FanucIssues in forum Fanuc
    Last Post: 05-05-2009, 01:24 AM
