CAN ANYONE TELL ME ANY THING ABOUT THIS MOTOR,AND CAN I USE MY StepMasterNC SOP-1 1 axis bi-polar stepper motor drives
Vexta Stepping Motor C8384-9212H 2-Phase
2.5 VOLTS 4.4 AMPS
SQ7 01598
ORIENTAL MOTOR CO. JAPAN
2.5 VOLTS 4.4 AMPS
SQ7 01598
Someone else may correct me, but I really don't see a way for those motors to be a good match for that controller no matter how they are wired. Sorry.
how many wires are on these steppers?
Easy there Stepmaster guy. I know you want to pimp your product and that it cures the sick and all, but my advice that this wasn't going to be a good match had nothing to do with your brand specifically.
Quite simply, a motor requiring 4.4 amps unipolar will still need over 3 amps run bipolar series, and well over 6 bipolar parallel.
It will work, of course, but if you can explain how any driver delivering only around 60% of the power it needs will give a good match for this motor I'm all ears.
If these are 8 wire unipolar motors they would most likely work fine for most applications. No, you wouldn't get 100% rated torque more likely upwards of 85%. Guess what? For most small appications that is fine. I wouldn't recommend purchasing steppers rated above a drives output, but if they are what is on hand, they may be fine for your application. Most people halve amperage rating when modifying unipolar motors for bipolar use. Effectively the amp per phase will be slightly higher than half the labeled amperage, but it is hard to pinpoint this point when modifying steppers.
keepitsimple they are 4 wire motors
what would be a good driver for them
Any bipolar driver with 4.4 amp capability, Keling, Gecko etc.
The stepmasterNC drive will drive them, but if you need the full torque, you will certainly need higher amperage output drive
So would a half amp driver, the driver you are talking about would deliver only half the current that this motor needs and has a max voltage of 30V so really you are looking at supplying it 24V max or the bemf can over voltage the driver.
Running at only 24V and half the rated current would give a terrible performance.
most likely have the speed and torque than using the msd542 or the kelling driver (At 45V) that that mcp spoke about (Why are mcp advertising a competitors product?)
