585,933 active members*
3,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > nose radius/P numbers
Results 1 to 9 of 9
    May 2015
    35
    I only program in IGF mode. I have the OSP 5020L control. On the tool data page, are the x and z nose r comp numbers simply the radius on the insert? Do I enter the insert radius on both the x and z? Or am I mistaken? Also, do I have to enter a P number? What is the P number?I have been reading manuals for hours and I am still not certain. Any help would be greatly appreciated.
    Jun 2015
    4154
    Re: nose radius/P numbers
    hy jmooresshop
    are the x and z nose r comp numbers simply the radius on the insert ?
    yup
    yeeess; i really have no clue why there are 2 fields for that
    Or am I mistaken?
    no, you are always right
    if you wish + it may help
    try 3
    at least you are not wrong ...
    post #7 in here : https://www.cnczone.com/forums/okuma...l-osp7000.html
    kindly
    May 2015
    35
    Well, the boring op is cutting .06" under. But if I change nose comp to zero, it bores to the correct size.
    Jun 2015
    4154
    if you wish for a full diagnosis, pls share tool geometry, drawing before & after the operation, and code
    or don't share the code, and i will write it instead / kindly
    May 2015
    35
    I figured it out. The P value was the problem. The P value determines which quadrant the nose comp is figured from. But I am very grateful for your response. Your recent advice has been helpful.
    Quote Originally Posted by Jmooresshop View Post
    Can you explain P value that what you said it determine the quadrant ,so what true number we can put for P
    Feb 2006
    992
    P tell machine where is tool radius point. Click here for picture and better picture click Here
    So depend on how your machine setup relative you the part, that is how you put in the P.
    The best way to learn is trial error.
    Jun 2015
    4154
    hy tungnguyen, i also have an image P is telling the cnc where tool nose radius center is, relative to offset value / kindly
    Apr 2009
    1262
    Kitty's guide is correct for P values. As you can see some have only X and some only Z values for radius comp, thus two registers, but only one is used. If you use the P values, it will automatically correct for data entry error such as sign +, - direction entered wrong. Also you can only enter 1 value and it will take the larger number and use it for comping correctly when the P is used. 3 is normal OD and 2 is normal ID turning. If no P value is used, then sign and value matter for the comp registers.
    Best regards,
    Experience is what you get just after you needed it.
  1. Tool nose radius G42 and G41, T=
    By ecsurfer2 in forum CNC Swiss Screw Machines
    Last Post: 01-11-2017, 01:11 AM
  2. Tool Nose Radius
    By speeeeed in forum Haas Lathes
    Last Post: 07-20-2014, 04:02 PM
  3. Nose radius compensation
    By gunda in forum Okuma
    Last Post: 06-02-2013, 01:12 PM
  4. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  5. G42 Tool nose radius.
    By al-108 in forum Okuma
    Last Post: 03-02-2008, 08:39 AM
