584,865 active members*
4,985 visitors online*
IndustryArena Forum > Material Technology > Composites, Exotic Metals etc > Tools for machining solid carbon (not carbon fiber)-more posted
Results 1 to 6 of 6
    Mar 2007
    7
    Hi there,
    Does anybody have experience cutting carbon. I'm talking about solid carbon, not carbon fiber. There are many different grades but mostly the problems I'm having are with chipping and tool wear as it's very abrasive. Do you recommend slower speeds and higher feeds or faster speeds and slower feeds? Faster spindle seems to dull the tool quicker (rounds the edges) and slower spindle seems to chip the material. Using diamond roughers and diamond coated tools but price is sky high. Any suggestions??
    Mar 2004
    1661
    Chips? Nah, rather dust. I've been using high speed AND high RPM, but I didn't pay the mills though, it was always diamond ends.
    Jan 2007
    103
    diamond coated tools are the way to go.
    the prices are huge like 125$ for a 1/4 endmill.
    they should last and last and be well worth the money
    if you are running them right. my local supplier is CVD in London Ont.
    Canada
    svenakela is right high speeds and feeds like over 10,000 rpms
    maybe close to 30,000 if you can get it.
    Mar 2006
    2712
    You will need a dust collecting system, some sort of breather, filter respirator thing and a lot of soap. Personally, I used a lot of "Protek", that lotion type stuff you rub into your pores. It helps washing-up after cleaning up the area & machine. In reference to your original question, it was answered above. Also, plan your cuts to avoid the breakout at corners, even if you may have to come back from another direction. Happy dust cloud!
    DZASTR
    Mar 2007
    7
    More questions then I guess
    Ok, thank you for the replies. Let me ask you a couple more things then.
    I just started working with this material and I'm using the diamond "grit coated" cutters (or whatever the proper term would be) for roughing and have limited access to diamond coated finishers, but mostly uncoated carbide for finishing. All 2D parts, pockets 2d contours and such, no 3d shapes. The max spindle I can run is about 7000. For lets say a 1" rougher, what would you recommend for cut depth and stepover and such? Am I better off taking many .010" steps or 1 giant step? Go to depth then use small xy steps? I'm starting from ground zero and totally confused with this stuff. I've cut different materials before but this stuff is really tricky. Hats off to anyone that has this material conquered!
    By the way the stuff I'm cutting now is EK20 if anyone has worked with that. The part is about 5"x5"x.200 with some shallow pockets and a couple 1" bores through. Anyway, thanks a lot for your advice
    Mar 2006
    2712
    You may want to look into Severance Tool for carbide "diamond cut" burrs/endmills/routers.
    ADD: cvddiamond.com diamond tool supplier, pricing?
    DZASTR
  1. Carbon fiber
    By turmite in forum Composites, Exotic Metals etc
    Last Post: 01-08-2014, 03:57 PM
  2. carbon fiber
    By cncsdr in forum MetalWork Discussion
    Last Post: 05-23-2006, 05:25 AM
  3. Machining Carbon Fiber Rod
    By cncadmin in forum MetalWork Discussion
    Last Post: 03-12-2005, 05:03 AM
  4. Carbon fiber
    By CNC Pro in forum Community Club House
    Last Post: 03-13-2004, 11:32 AM
  5. carbon fiber
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 01-23-2004, 10:40 AM
