Hello,
I have the next DIY machine
but now I would like to improve the rigidity of my Z axis replacing the 20mm bars with prismatic 30mm guides, like this
the tool will work nearer of the X axis and the rails look solid, but i don't like the Z axis plate. Although will be 10mm thick of steel and I'll take advantage better the travel of this axis, this plate looks the weakest point. How are reinforced the Z axis in industry models. I thought to add an aluminum "T" profile to each side, like so
would it be enough? I would like to run a FEA analisys, but I don't know the cutting force values I could use for a router of 1530W, 8mm end mill, cutting 4mm depth of cut on hard wood.
Thanks in advance
