585,959 active members*
4,632 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > NPN NO proximity sensor resistor enquiry
Results 1 to 12 of 12
    Feb 2013
    81
    I am planning to use proximity sensors for my home and limit switches for Mach3. NPN NO sensors. They will be supplied by 24v going to a generic 5 axis board ( 5v)
    Am I correct in thinking that means the black wire to the BOB from the sensor will also be receiving 24v, which will potentially damage what is a 5v board?
    If thats the case should I not add a resistor somewhere to lower the voltage from 24v to near 5v to the BOB?
    Any info or links most welcome.
    Thanks.
    Feb 2013
    81
    Re: NPN NO proximity sensor resistor enquiry
    Proximity spec
    Set up distance 0 - 3.6mm
    Detection objete Magenetic
    Effective voltage DC: 12 - 24V AC: 110 - 220V
    Detection distance 4mm± 10%
    Response frequency DC:0.5kHz
    AC:25Hz
    Working voltage DC:6 - 36V
    AC: 90-250V
    Control output DC: NPN / PNP:?300mA DC 2 wire:?200mA
    AC :400mA
    Loop protection DC :reversal connection protection protection, surge avsorption ,load short-circuit protecrion
    AC : surge avsorption
Name:	npn wiring.png
    BOB
    Mar 2007
    2083
    with the BOB in your photo you don't need the pull up resistor shown in the diagram
    Attachment 402398
    John
    PS
Name:	limit switch connections.jpg
    Feb 2013
    81
    Excellent info thanks!
    Just out of interest is the db25 1205 BOB also optoisolated for the same proximity sensors?
    Mar 2007
    2083
    yes
    the 5 inputs to the PC printer port (or motion controller ) are opto-isolated
    the 12 printer port outputs are not isolated but they are buffered by two 74HHC245 IC's that ensures there is enough current drive
    to the opto-islaters inside the stepper drivers
    note-
    the limit switch common is connected to the PWM 0-10V analogue spindle comtrol common
    so you will need to ensure the spindle speed control VFD you use has an input that is isolated from the mains
    John
    ericks Guest
    I have the same bob....just be aware that the lm317 gets quite hot when you use 24 V
    Feb 2013
    81
    Quote Originally Posted by john-100 View Post
    note-
    John
    Now thats interesting! The GND pin suggested to use as the common on my blue board doesnt seem to work so i'm using the GND next to the 5V in. Good point about limit switch common is connected to the PWM 0-10V analogue spindle control common, I didnt know that.
    I'm using a less well known VFD, an XSY-ATI. No idea about the isolation, the BOB is wired to the VFD on the control side. Spindle ON/OFF is fine but speed not working in Mach3? the two things might be connected.
    Attachment 402426
    Feb 2013
    81
    Quote Originally Posted by ericks View Post
    Good to know. Perhaps it would do not harm to add a 3.3k resistor, which would take the voltage down to around 5.8v or something. The Im317 would like that
    ericks Guest
    I am just using 12 V, you don't want less than 12V! Your pwm to voltage converter requires more than 10 V
    Feb 2013
    81
    Ah right your talking about pwm to voltage convertion. More than 10v. Gotcha!
    Mar 2007
    2083
    If I converted my mini lathe with a spindle motor speed control more like this KB electronics board or a clone
    Attachment 402430
    Attachment 402432
    the entire circuit board is live
    and you need a BOB with a PWM to analogue control that is isolated from the rest of the BOB
    some thing like CNC4PS's C6
    Attachment 402444
    John
    Feb 2013
    81
    the entire circuit board is live and you need a BOB with a PWM to analogue control that is isolated from the rest of the BOB
    John
    Ok good point. I need to look into what the both BOB's I have are fitted with. At the moment I am wired to the VFD as per the image below.
    Attachment 402460
  1. Replies: 3
    Last Post: 06-26-2018, 06:56 PM
  2. Npn NO proximity sensor question.
    By silvs in forum CNC Machine Related Electronics
    Last Post: 05-03-2018, 06:59 PM
  3. Proximity sensor wiring
    By Lindzr in forum Automation Technology Products
    Last Post: 08-16-2017, 01:29 AM
  4. CRP's Proximity Sensor Kit
    By rwskinner in forum Avid CNC
    Last Post: 02-12-2014, 04:07 AM
  5. BB does not read +5 from proximity sensor
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 03-25-2012, 02:01 PM
