585,978 active members*
4,669 visitors online*
    Nov 2016
    Trafimet Torch
    I have a matcut 50 plasma cutter with a Trafimet A81 torch on my CNC table.Even with new electrode and nozzle I cannot get it to cut at 90 degrees to the plate being cut.
    Would a machine torch be better?
    Any advice would be appreciated.
    May 2015
    686
    Re: Trafimet Torch
    I've used a Trafimet S75 machine torch on a 50 amp Everlast and have been lucky enough to receive some guidance from R-tech in the UK who use a rebadged Everlast on their range of tables. If you were to buy a new torched based on what they've said, you would be better off with a tec.mo PM70 machine torch which they now use on all of their tables.
    They said:
    the reason you are getting poor cutting with these machines is the torch the ptm60 it is now a old design blow back torch
    you need a better torch look at the pm70 by tecmo (http://www.tecmo.it/upld/repository/File/03.PH.pdf) this will fit and use the same consumables as a powermax 45
    we use these now on all our machines
    I've since sold my Everlast and intend buying a Hypertherm 45XP.
    I think a machine torch would be much easier to keep square but whether that results in a square cut remains to be seen.
    Rod Webster
    www.vehiclemods.net.au
  1. DIY THC, Prolox 60 (Trafimet Ercocut s45)
    By the_muck in forum Waterjet General Topics
    Last Post: 01-22-2013, 02:44 PM
  2. Trafimet ergocut S45 consumable life?
    By balestraio in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-04-2012, 08:15 PM
