586,011 active members*
4,140 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Help!!! What voltage is the consew 3/4 brushless motor
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    May 2006
    309
    Re: Help!!! What voltage is the consew 3/4 brushless motor
    Quote Originally Posted by crl1_1 View Post
    black=left potentiometer pin
    green=middle
    red=right
    Thankyou very much for your help. Now I got my motor to work, and it has a stable speed. Can I now use the potentiometer to control the speed instead of the buttons on the control box in order to regulate the speed without loosing force on the motor?
  2. #22
    Jul 2018
    58
    Quote Originally Posted by jaru-eri View Post
    No problem. Yes you can control the speed but make sure you select 4500 as your highest speed and 500 as your lowest in the settings. you will also have to always return the potentiometer to 0 everytime you turn it off otherwise it wont start.
  3. #23
    May 2006
    309
    Yes, I have the same problem regarding turning to zero. My motor starts first when I have turned the potentiometer half the way around (in the middle position), so I have a very narrow scale for the speed regulation. I have tried with a 1K pot. Will I get a wider scale if I decrease this value from 1K to f.ex. 220 ohm?
  4. #24
    Jul 2018
    58
    25k will work fine, if yopu want a finer scale you can use a multi turn wire wound potentiometer
    http://a.co/d/2UR1job
  5. #25
    Jun 2011
    68
    Quote Originally Posted by sclelectronics View Post
    Just found the Speed adjusting pot.....
    It is a 25k ohm......
    Here is a photo of how it is wired....
    Stuart
    Posted this in the Taig area
    I now control the speed with C69 by CNC4PC
    Stuart
  6. #26
    May 2006
    309
    Stuart
    Thankyou for the information. Do the 3 wires at the lower left have something to do with the speed adjustment or are they for something else? And can the c69 be used as an interface for controlling the speed through Mach3?
  7. #27
    Jun 2011
    68
    In the lower right of the photo, is the 6 position connector plugs into the controller.
    On the left, centered in the photo is the potentiometer. Just giving you a reference to where the wires go.....
    Also, yes I can control the speed directly through Mach 3 now...
    My Taig is controlled through an ESS. I am using the 2nd port on the ESS to control the C69 speed control board.
    The latest ESS plug-in allow speed governing.
    So I just setup my rpm pulse sensor...I am using hall effect sensor for this.
    So I have a lot of tweaking to do now!!
    Stuart
  8. #28
    May 2006
    309
    I found that my controller first trigger after the pot has provided about two volts to the input in the control box and that´s why I cant use the full range of the turning scale. So the solution have to be to put a resistor between the black wire and the pot in order to get a wider scale. This resistor has to be around half the value of the pot. The scale of the pot. will not provide a linear speed increasement to the motor.
  9. #29
    Jun 2010
    18
    Stuart
    I know this is an old thread, but I'm really hoping you could provide some more details of the ESS - C69 setup that you've got going. I have a spare ESS and a C6 board laying around, and I'd like to put them to use with one of these motors on a lathe. (C69 is pretty much the same as C6, just doesn't take up a whole parallel port.)
  10. #30
    Jun 2011
    68
    No real magic here....
    In the ESS plugin:
    I configured the port 2 on my ESS... Just like Port 1.
    Also setup the required PWM freq.
    Then under Ports and Pins, for port 2
    I enabled pin 14...Spindle PWM.
    Finally on the C69, adjust the control voltage to 5 volts when at max rpm...
    hth,
    Stuart
  11. #31
    Jun 2010
    18
    In the ESS plugin:
    hth,
    Stuart
    Thanks.
    Just to make sure I've got this all...
    (1) Analog output of C69 goes to the wiper on the pot, when tuned to 5v max output
    (2) Analog ground of C69 goes to the COM pin on the pot
    (3) potentiometer reference voltage doesn't get used, because it's insanely high and you don't want to let the smoke out of the speed control board?
    Are you using the relay output for anything? I saw a thing from one guy that used an NO relay on that line to force it to 0V in order to avoid the controller error thing where it thinks the hall sensor has failed.
    You're not using any external circuits to tweak the power level? Just the potentiometer on the C69?
  12. #32
    Jun 2011
    68
    Yes you got it all....
    Wiper and Ground connections to the C69.... no Reference voltage signal
    No other external circuits,
    Stuart
  13. #33
    Jun 2010
    18
    Stuart
    Thanks.
    With the external controls like this, does it still have a minimum of 500 rpm? (I'm looking at a lathe application, and I'd like to avoid using any of the original pulleys / countershaft setup. Problem is, 6:1 back gearing at 500 rpm only gives me a minimum of 83 rpm, and I'd really like to be able to get down into the 30s without having to shift belts around.)
  14. #34
    Jun 2011
    68
    When tuned ..
    It will give the same speed range like the manual Pot. control!
Page 2 of 2 12
  1. G540 to Consew Type Servo Sewing Machine Motor
    By IdefixRC in forum Gecko Drives
    Last Post: 10-31-2019, 11:57 PM
  2. Wiring new motor ? Consew 3/4 hp
    By Gamble in forum Benchtop Machines
    Last Post: 10-28-2017, 02:35 PM
  3. 320X motor voltage problem, motor is unpowered by drive
    By RustedOut in forum Gecko Drives
    Last Post: 03-15-2013, 05:57 AM
  4. Brushless Motor for X2?
    By skmetal7 in forum Benchtop Machines
    Last Post: 06-26-2010, 11:42 AM
  5. brushless dc motor
    By microstep1 in forum CNC Machine Related Electronics
    Last Post: 09-06-2008, 01:34 PM
