I am trying to figure out what voltage the motor is in order to buy a controller for it. Does anyone know how I can test it while it is running? The model is consew csm 1000. Any help greatly appreciated
The CSM1000 is a 1/2hp motor at 500w. The CSM3000 is the 3/4hp at 750w. I can measure the 750w unit but I don't have any of the CSM1000 units anymore. I suspect you could determine the voltage since you know the wattage and could measure the resistance.
if its a 3 phase induction motor then all you need to do is measure the amp draw at full load and find a vfd of equal or larger capacity.
you then program the vfd for the volts/hz the motor needs.
if these are permanent magnet motor the same issue applies but you need to find a vfd that can drive a permanent magnet motor. you've got a lot of choices.. to include electric E bike controllers at the low end of the spectrum.
I've never pulled one apart, but I can say with certainty it's not a brushed DC motor. I looked at the motor controller a few years ago, but I don't remember exactly how it was setup. My 750w CSM3000 will do about 4200 RPM in case you were thinking of using it to drive a spindle. Some years ago, I also got a nice shock touching a motor wire, so I'm thinking it's probably a touch more than 48v.
AFAIK it is a BLDC motor but have no details on the controller, whether it has hall effect commutation etc.
Al.
Albert E.
Here is a PDF and a web page where you may be able to call
http://www.consew.com/files/112347/I...ls/CSM1000.pdf
Consew Model CSM1000
Mactec54
I wanted to buy a vfd but i could not find a 110v that was suitable. I found this and the motor definetly has the hall sensors 5 wires and 3 main power wires. I will use a potentiometer to control the speed seems more simple to me than using a vfd. I just wish i knew the voltage I have looked around alibaba and for similar size motors they appear to be around 48v
One of the A-M-C servo drives will drive it, using a simple 5k pot for speed control.
Al.
Albert E.
Will it be possible to mount a potentiometer directly to the foot pedal input on the controller and use that for speed control?
Ah, I understand what you're talking about now. I've seen it before with cheap motor drivers. On a sewing machine it isn't really noticeable because at high speed there is a minimum constant load. I think in your situation it has to do with the fact the spindle doesn't really put a load on the motor so it has trouble stabilizing at a given RPM. If the actual speed control is PID based, then it's going to be in those settings... not that you can change them. You may be able to look into controlling it with something like a VESC controller where the parameters can be changed.
In the lower right of the photo, is the 6 position connector plugs into the controller.
On the left, centered in the photo is the potentiometer. Just giving you a reference to where the wires go.....
Also, yes I can control the speed directly through Mach 3 now...
My Taig is controlled through an ESS. I am using the 2nd port on the ESS to control the C69 speed control board.
The latest ESS plug-in allow speed governing.
So I just setup my rpm pulse sensor...I am using hall effect sensor for this.
So I have a lot of tweaking to do now!!
Stuart
