585,712 active members*
3,934 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > haas vf2 error 131 tool not clamped
    Feb 2009
    13
    We have a Haas vf2,
    Today the machine has stopped twice with the same error 131 tool not clamped.
    This has only happened to tool number 5 out of 10 different tools in the carousel which are all used in the same programme.
    What would be the most likely cause of this and how do I fix it ?
    Jun 2004
    6618
    Re: haas vf2 error 131 tool not clamped
    I would think it is a dirty tool holder or maybe a loose or incorrect pull stud. Possibly an out of spec tool holder.
    I would suggest a good leaning of the spindle pocket and tool holders.
    Lee
    15362
    Quote Originally Posted by jeromep View Post
    We have a Haas vf2,
    Most likely the Proximity switches at the top of the spindle for the tool change, may need adjusting or one is starting to fail
    Mactec54
    Feb 2009
    13
    hi,
    i ahve found the problem the bellville washers that hold the tool holder up in the spindle were mostly all broken, bought new unit off haas £400 fairly easy fix
  1. haas lathe spindle clamped HL-2
    By Welder2022 in forum Haas Lathes
    Last Post: 08-26-2018, 04:37 PM
  2. HAAS TM2P tool changing ERROR
    By rally210er in forum Haas Mills
    Last Post: 02-17-2017, 03:15 PM
  3. Chuck cannot be clamped/Unclamped
    By mohanad1820 in forum Maintenance DIY Discussion
    Last Post: 02-09-2014, 06:17 PM
  4. Chiron FZ 08 - Fixture not Clamped
    By Etech17 in forum DNC Problems and Solutions
    Last Post: 01-12-2010, 05:16 PM
