585,954 active members*
4,529 visitors online*
    Mar 2004
    369
    CHNC-I limit sensors
    We are retrofitting a 1986 CHNC-I that originally had the General Numerics control. The axis servos and drives were already replaced with Parker/MTS brushless motors/drives, and we now have those working very well. Now, on to the home and limit sensors. Taking them off the machine, we just see "MicroSwitch, Freeport IL", no part number or anything! The parts book shows a Hardinge part #, but that doesn't help much. Does anyone know what these sensors are? I'm pretty sure they are actually sensors, not mechanical switches, as they don't click when actuated.
    The sensors all have red, black and brown wires. Typical in industrial controls, red is + supply, black is ground and brown is the sensor output. The wiring diagram kind of confirms that, but we don't know what voltages these sensors should be supplied with.
    Thanks in advance for any info anyone can provide!
    Jon
    Mar 2010
    1852
    Re: CHNC-I limit sensors
    They're called "Hall effect sensors." Transducers that switch by sensing a magnetic field. No contact necessary. Don't remember for sure, but I think the machine is 12V. They generally operate at 6-36VDC.
    https://en.wikipedia.org/wiki/Hall_effect_sensor
    Mike
  1. Replies: 25
    Last Post: 10-04-2018, 01:55 AM
  2. Npn NO proximity sensors
    By Kal22378 in forum CNC Machine Related Electronics
    Last Post: 05-18-2018, 05:16 PM
  3. optical slot limit sensors
    By travis_farmer in forum DIY CNC Router Table Machines
    Last Post: 05-01-2017, 01:23 PM
  4. proximity sensors
    By FordGalaxy in forum Benchtop Machines
    Last Post: 06-02-2012, 09:36 AM
  5. Sensors selection
    By Akros in forum CNC Machine Related Electronics
    Last Post: 02-08-2010, 11:51 PM
