585,749 active members*
3,759 visitors online*
Page 1 of 3 123
Results 1 to 20 of 46
    Jul 2003
    1754
    small mill project.
    I got a small used cnc mill a year or 2 ago and have not had a chance to go through it and fix it up. The ways (sliding surfaces) look really good - but most everything else needs a little TLC. (ball nut mounts not parallel to the slides and such)
    The mill is torn down to its individual parts and being gone through. Currently working on the Z axis slide. Again - the sliding surfaces look great - but the mating surfaces are a bit off.
    What to do.. Mount it on the big mill of course!
    Using some ground rod/123 blocks to make sure the ways are parallel and perpendicular to the K&T.
    True up the mounting surfaces... (took off about .002")
    And done..
    Things to do yet on the Z axis column..
    - mill the relief for the ball screw nut further. (go into the more later)
    - mill the mounting holes so they are symetrical. (they are all over the place.)
    - mill some line up edges for mounting to the base. (I am adding a 4 inch riser block so there is more space between the spindle and the table)
    I think that is it for now.
    Jul 2003
    1754
    Re: small mill project.
    This is what really set off the 'go through'
    The x axis ball nut block was not mounted parallel to the ways. (poor thing) and the more I dug into it - the more little problems there was. (not unexpected - this was a prototype)
    This should be one solid machine once I am done.
    sam
    Jul 2003
    1754
    Found a chunk of cast iron (part of an old grinder..) to make a 4 inch riser. (this is to raise the Z column)
    I needed a piece about 7"X5"X9".
    - - - Updated - - -
    Started on the base (y axis)
    mounted it similar to the vertical column.. Then trued the feet to the ways then cut some reference points..
    Now - flip it and make some measurements and reference points.
    - - - Updated - - -
    4" Riser block kit... slight machining required. ..
    Jul 2003
    1754
    The hacking has started...
    Jul 2003
    1754
    Kinda like watching paint dry.. Guess I should work on some other things..
    it is 'squared'... Now on to machining...
    Jul 2003
    1754
    the base and vertical off the mill.. I am happy so far.
    Now on to the riser block...
    Mounted - once I get a side flat - it should be easier to square up. I can rotate the table and do 2 sides with one setup - which makes them very square.
    First cut..
    First cut finished... Going to have to take maybe another .05" or so.
    Jul 2003
    1754
    3 sides square... Getting there. (just going to eek it out..)
    Finally to the point of machining into the shape I need... (squared on 7 sides)
    Some rough machining...
    Jul 2003
    1754
    Other side roughed..
    Some progress... I think I am going to make the over-all riser 5 inches.. (I can always make it shorter...) The column side is done. It fit together perfectly.. Very happy.
    Table rotation for finishing up the angles..
    finished end..
    Like a glove... (back)
    Jul 2003
    1754
    Front..
    Line-up grove...
    Top support
    Whole thing...
    Front
    Jul 2003
    1754
    Finally got the bottom finished (I think)
    - - - Updated - - -
    Yum...
    - - - Updated - - -
    seems to have bolted together.. Now to make sure it is perpendicular in both planes..
    Jul 2003
    1754
    Finally got the little mill back on the big mill.. took a bit if finesse to level/square the base/Y axis. (without warping the casting..) We have a .0005"/10" level that works very well for these situations.
    Currently the column is <.001 square over its distance. (both directions..)
    sam
    Jul 2003
    1754
    Now to get the rest lined up...
    - - - Updated - - -
    Redoing oil lines.. It didn't have metering valves and the Y axis ball screw was never plumbed..
    - - - Updated - - -
    I hate plumbing.. Getting there with a few side trips. Had to mount the X axis ball nut. It was so out of square that I machined 2 new holes instead of trying to use the existing 4 holes. (also made it easier to mount with the oil plumbing.)
    Checked clearance with the table...
    Another view.
    - - - Updated - - -
    Good enough.. (if it works)
    Jul 2003
    1754
    Ran some oil through the saddle. Checking the flow. These are bijur flow regulators I got off eBay. I think they will work great. I slid the y axis on and it slides very easy on the film of oil.
    Sam
    (These are not made for 4mm tubing - but I found out the pressed in reducer removes easy. I just need to be careful that the tube doesn't protrude too far into the regulator - they don't flow then.. )
    - - - Updated - - -
    Things like this - the x axis stepper mount was getting in the way of the oil fittings.
    So - snip snip here and there...
    Getting things lined up pretty good. The really sucky thing is the table is slightly narrower than the saddle. (you can see the the ways and oil troughs) No one knows the story behind that goof. I plan on grafting an aluminum piece that bolts to the table to extend it over the ways. (mainly I want the oil to mostly stay under the table.)
    Jul 2003
    1754
    Without going past the ways - it looks like travel will be 10" x 7-3/8" X 10-5/8" (XYZ)
    - - - Updated - - -
    1/2 done. Went suprisingly smooth...
    Jul 2003
    1754
    This is going to work well to fix the table width/way issue.
    - - - Updated - - -
    Some quick tests...
    Jul 2003
    1754
    sorry about the quality...
    Jul 2003
    1754
    Looks like the nose of the spindle will be 3 inches above the table.. I think that will be just fine.
    Thank goodness for soft limits...
    Jul 2003
    1754
    Going to re-use the z axis way cover. I needed to add a extention to the ways so the accordion wouldn't get caught.
    Another exciting video...
    some random videos of making the way extension...
    Jul 2003
    1754
    The reason why I added the 5" Z spacer...
    May 2015
    1422
    Lovely work, thank you for (1) remembering to document as you went - something I never remember to do until it's too late - and (2) sharing it with us.
Page 1 of 3 123
  1. small EDM project (DIY EDMers welcome!)
    By acannell in forum EDM Discussion General Topics
    Last Post: 01-08-2014, 02:41 PM
  2. My Manual small mill project
    By ZipSnipe in forum Vertical Mill, Lathe Project Log
    Last Post: 05-07-2013, 05:03 AM
  3. Need Help with Small Project
    By mgilbert754 in forum MetalWork Discussion
    Last Post: 08-17-2007, 05:37 PM
  4. Small Mill Part/Project/Thing Showcase
    By BrendaEM in forum Benchtop Machines
    Last Post: 08-01-2007, 06:25 PM
