585,771 active members*
4,435 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > Automation Technology Products > 570 oz/in steppers with different amp ratings. What does that tell me?
Results 1 to 7 of 7
    Mar 2011
    357
    AT has several 570 oz/in steppers. There are some that are rated at 3.5 amps
    and they have some that are rated at 5 amps
    here
    How can motors with the same torque have different current ratings and what does that tell me?
    Re: 570 oz/in steppers with different amp ratings. What does that tell me?
    Look at the inductance, and also the torque curves.
    The higher current motors will have much lower inductance,which means they have more torque at higher rpm, for a given voltage.
    Quote Originally Posted by tkms002 View Post
    here
    Pls check specification here. They are different body size and specification:
    https://www.automationtechnologiesin...lat-381-oz-in/
    https://www.automationtechnologiesin...lat-570-oz-in/
    Mar 2011
    357
    Quote Originally Posted by automationtechinc View Post
    you have 570 in/oz steppers rated at 5 amps and 570 in/oz steppers rated at 3.5 amps.
    I see the 3.5 amp steppers have a much higher inductance but I am not an electronics guy so I really don't know what that means in practical usage.
    Jun 2011
    692
    Higher inductance in a stepper means the torque falls off faster at high RPM's (with the same voltage.) So basically, with the same voltage the 5A stepper will be able to run faster than the 3.5A one.
    Mar 2011
    357
    Quote Originally Posted by skrubol View Post
    So all other things being equal lower inductance is always better?
    Jun 2011
    692
    That might be oversimplifying, (quality isn't just determined by power,) but I think you could say will all else equal, lower inductance will mean more torque at higher RPM's..
  1. stepper ratings
    By kool-lites in forum Stepper Motors / Drives
    Last Post: 12-20-2010, 11:01 PM
  2. CNC Machine Ratings
    By Posimech in forum MetalWork Discussion
    Last Post: 09-10-2010, 08:00 PM
  3. CNC Ratings
    By Danny McKay in forum Commercial CNC Wood Routers
    Last Post: 03-02-2010, 12:08 AM
  4. Transfomers and va ratings.
    By m1ck in forum CNC Machine Related Electronics
    Last Post: 10-09-2008, 02:50 PM
  5. Transformer ratings
    By xairflyer in forum CNC Machine Related Electronics
    Last Post: 05-08-2005, 12:28 PM
