I'm looking at adding the ATC/PDB to my 1100 and as part of that I am looking at upgrading my compressor. I have one of the small California Air Tools units (the 4610 model) that I use right now just for a fogbuster, and I suspect it might not be enough. The Fogbuster uses a decent amount of air and from what I've read a lot of people like to run their PDBs at ~120PSI which is the cutout pressure on the compressor. I do like how quiet the CAT compressors are and am considering one of the slightly larger models.
This one uses 2HP pump and larger tank so it has >2x CFM over mine. Kickoff pressure of 125PSI.
https://www.ultraquietaircompressor....CAT-10020C.htm
This one is a higher-pressure (and lower CFM?) model and has an automatic drain which is nice. A little more expensive:
https://www.ultraquietaircompressor....-20015HPAD.htm
Just curious if anyone else has either of these or another QUIET compressor they'd recommend. Not looking for anything crazy like a screw or scroll compressor as I don't use air for anything except the Fogbuster and cleaning off parts.
