585,763 active members*
4,069 visitors online*
    Y axis not moving to scale
    You guys have been a great help getting me up and running, but I have one more issue to fix. My "Y" axis is way off. I'd say it's running 60% of length programmed. I recently put a new microstepper controller on, but it was a exact replacement of the original. Please let me know if you have any questions on my setup or any suggestions to fix my issue. Thank you!
    Apr 2004
    5735
    Re: Y axis not moving to scale
    If it's consistent about that, what happens if you increase the steps/unit by 40%?
    Andrew Werby
    Website
    Apr 2014
    215
    Quote Originally Posted by originalsigns View Post
    Have you set the microsteps exactly the same on bother drives?
    You have not given a lot of information with which to help.
    If all you did was change the drive it sounds like the microsteps setting on the drive (either adjustable by dip switches of software..... Or if it's a gecko, it will be locked to 10ustep resolution)
  1. Scale in Z axis
    By becikeja in forum BobCad-Cam
    Last Post: 08-28-2016, 01:27 AM
  2. Replies: 1
    Last Post: 10-02-2015, 05:34 AM
  3. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  4. Z AXIS - Moving bearings or moving rails ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-28-2012, 06:22 AM
  5. Z DRO moving, axis not moving
    By JC50 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2011, 02:49 AM
