I'm working on an MV-40 with a MF-M4 control. I was initially getting a spindle cooling unit error and while I worked on that I had the machine off. When I powered the machine up I had a fuse break alarm. The Fanuc Power Unit had a bad fuse and so I replaced. Now when I power the control up I get a EX:098 Panel Test Mode and I cannot use any buttons on the control. Is there a switch on board I am supposed to flip or a reset button a circuit board? I have never seen a Panel TEST Mode before.
