Hello everyone
I just got my MPG and was thinking on wiring it up to the Parallel port to keep the I/O pins on my ESS free for future things
Is that a good idea ? Should i go to the ESS or it don't make a difference ??
Hello everyone
I'm not sure if you can use parallel port and ESS at the same time?
You could go with the UC300ETH, it has 5 LPT ports with about eighty I/Os then you will likely not need to use any additional ports. And it is cheaper than the ESS.
No, you can't use both. One or the other.I'm not sure if you can use parallel port and ESS at the same time?
We will soon find out, I got a PCIe parallel Port card this weekend
