586,011 active members*
4,215 visitors online*
Results 1 to 11 of 11
    Apr 2017
    41
    recommend a machine for me
    i’ll be cutting acrylic up to 1/2”. i know nothing about laser cutters but i have a lot of experience with cnc routers. i’d like to stay within $3k.
    Nov 2015
    371
    Re: recommend a machine for me
    Actually, a CNC router may be more appropriate for cutting 1/2" sheets. The quality of the edges would be better.
    Apr 2017
    41
    Quote Originally Posted by Storen View Post
    most of the time it would be for 1/8” or 1/4”.
    Nov 2015
    371
    Quote Originally Posted by cromag27 View Post
    Still, the edges are not going to be as good as when cutting with a router. Is there any particular reason you want to do this with a laser?
    I would suggest getting some samples made with a cheap Chinese machine (under 3K) and compare them to the ones you've done with the router before you commit to this purchase.
    Jan 2008
    940
    I find that the laser gives me better edges on acrylic then my router. I even picked up a large job that a company with 2 Beisse routers sub out to me because the edges come out better.
    Nov 2015
    371
    Interesting. Aren't they concerned that the cuts from the laser are not perpendicular to the top surface? This could be a major problem for a lot of applications.
    What were the defects on the edges produced by your routers? The attached image shows what a routed edge should look like. You can't achieve this quality with a laser (not even close).
    Attached Thumbnails Attached Thumbnails 75d95daa9b6d88506fd6708e1686fbbd.jpg
    Apr 2017
    41
    i make smaller products for home aquariums and i feel my cnc router is overkill for a lot of which i make. some of my products do need to be welded together but it’s only thin acrylic. i have had things cut with a universal industrial series and it seemed to cut just fine for what i need it to do. just can’t find any info on how to order them or prices.
    Octo Aquatics – Custom Aquarium Products – Est. 2004, AZ
    Nov 2015
    371
    Cool products. Do you make the tanks yourself?
    Universal (ULS) makes very good machines but they are quite expensive. Probably an overkill in your case.
    For around 3K you can get a decent Chinese machine. See this thread - Link
    Jan 2008
    940
    They wanted a polished edge and the only wat to do that on a router is use the Onsud diamond bit for $1495.00 and they didn't want to go that much
    Apr 2017
    41
    Quote Originally Posted by fixtureman1 View Post
    you can also flame polish with a torch or use polishing compounds and a buffer.
    - - - Updated - - -
    i don’t make tanks anymore. used to though, both glass and acrylic.
    Jan 2008
    940
    - - - Updated - - -
    That will add to the cost as it is extra time and is easy to ruin a piece. I cut about 100 units at a time for them and sometimes up to 450 so that would be days worth of flame polishing.
  1. Recommend CNC Machine:
    By michaelxx in forum Benchtop Machines
    Last Post: 08-04-2018, 05:58 PM
  2. Please recommend me a machine !
    By jerzyk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-23-2012, 03:48 AM
  3. Recommend us a machine please
    By UWAM in forum Australia, New Zealand Club House
    Last Post: 09-12-2012, 01:56 PM
  4. Anyone who wants to build a machine (or can recommend something), LQQK!
    By FXC in forum DIY CNC Router Table Machines
    Last Post: 11-28-2009, 02:31 AM
  5. Please Recommend a Home welding machine
    By ThomasAlva in forum Welding Brazing Soldering Sealing
    Last Post: 08-23-2007, 07:34 AM
