585,996 active members*
4,061 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, is it possible to use rad comp in CZ plane, on lathe ?
    Jun 2015
    4154
    hello please, is it possible to cut attached groove, width 6.3, with a mill o6, using rad comp, on a lathe ?
    i wish to enable rad comp on the toolpath from image 2 ( now i code such stuff without compensation, and it requires too much time )
    i know that walls won't be parallel / kindly
    only for such operations, there is also the flexicenter from ews :
    https://www.ews-tools.de/en/products...exicenter.aspx
    in next video :
    ... 0:10 is the ews center-point : it requires good alignment between toolholder bore and spindle ( closed / clamped ); there is a special sleeve inside the toolholder, that may handle some dissalignment, but even so, is good to be sure, so to avoid the case when turret servos will be stressed, because, if things are not alligned, the clamping event will tend to move the turret and to put stress on the spindle
    ... 0:30 flexicenter appears, and at 0:43 it is adjusted; such toys are not balanced, but they deliver
    https://www.youtube.com/watch?v=akchngDvIEE
    Aug 2011
    419
    Re: pls, is it possible to use rad comp in CZ plane, on lathe ?
    Yes, it is possible.
    This is contour generation programming mode (side) function.
    G132 Z C L F (for CW)
    G133 Z C L F (for CCW)
    G119 compensation code
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hei kurmay, pls, if you have time, will you test the code from post 2 in here ( is only half a circle diameter 20, or 2 quarters ) : https://www.cnczone.com/forums/okuma...help-g132.html
    i onestly have problems with G132, but if i could make it work, then maybe also rad comp will work; otherwise, i am dead / kindly
    Jun 2015
    4154
    hello, finally, it worked : instead of G01 C... Z... i use a soubroutine CALL OSUB C... Z..., that automatically calculates feed and allows to make toolpath corections near the cnc panel, instead of going back at the pc and recreate the program.
    at this moment, same operation is running on 2 lathes, and each lathe has different corections; even if all is aligned, etc, there is an error when indexing between tools : for example, if a reamer is cutting after a drill :
    ... reamer center line will not be coaxial with the drill center
    ... also reamer toolholder will not be coaxial with drill toolholder
    such small differences sum up, and i don't wanna recreate the program each time something happens; i preffer to adjust it fast, near the machine; such parametric toolpaths require time to be coded, so i use them only for long-series ( > few weeks )
    another thing that i encountered was that for G0 C10, VSIOC is not always 10, but 370, or -710, etc; thus even if the displayed value is 10, sometimes C axis may be at least one full revolution shifted from that value
    i solved it by using MOD [ angle, 360 ], so to restrain the values between -360 and +360
    in the end, all works, and i managed also to eliminate the auxiliary movement associated with entering the comp ( G42/G41 ) and exiting the comp ( G40 )
    i wonder if is it possible to use imaginary vectors, but for this i will open another thread / kindly
  1. Replies: 2
    Last Post: 10-02-2014, 02:06 PM
  2. Feed Plane Overwriting Rapid Plane V26
    By Jbrown74 in forum BobCad-Cam
    Last Post: 02-21-2014, 02:17 AM
  3. Da plane! Da plane!
    By cncadmin in forum EnRoute
    Last Post: 11-10-2012, 08:30 AM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
