585,930 active members*
3,900 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Problems with Inlay pieces not getting cut correctly.
    Dec 2015
    37
    OK, so I have done inlays before with fairly large pieces and have not had any problems but not I am working with some fairly skinny pieces and for some reason the cuts are not coming out correctly.
    I am doing an inlay that will be .3" deep and I using a 30 degree vbit. the pieces is about 4 inches long and about 0.125" wide.
    When I run the simulation on Vcarve it looks correct. below is a pic of what the simulation looks like.
    However when I do the cut it looks like is is offset to the left. Not sure why that is but i have not seen this before when doing inlays.
    any help would be appreciated.
    Apr 2005
    304
    Re: Problems with Inlay pieces not getting cut correctly.
    As far as I can see from your photo, you wood is breaking away. I guess that you are cutting too much material in the final pass.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Replies: 2
    Last Post: 11-19-2013, 09:03 PM
  2. V21 inlay help
    By Benny555 in forum BobCad-Cam
    Last Post: 09-15-2011, 06:28 PM
  3. Help with CNC for inlay
    By pixel8tryx in forum Musical Instrument Design and Construction
    Last Post: 04-03-2010, 04:22 AM
  4. CNC for inlay
    By GuitarEng in forum Commercial CNC Wood Routers
    Last Post: 02-26-2008, 08:19 PM
  5. Inlay Help
    By jmarley in forum Musical Instrument Design and Construction
    Last Post: 02-26-2007, 04:06 AM
