585,575 active members*
3,727 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > G.Weike Laser > G Weike 1290 Suddenly cutting at half speed in curves only: HELP! PLEASE!
Results 1 to 12 of 12
    I run a maker space with 200+ members and they all want to use the laser cutter...all the time. Suddenly, 5 days ago, the laser cutter began to cut at less than half speed ONLY when cutting curves (in straight lines -- x axis only. y axis only, or straight diagonals, it still cuts at full speed). As soon as the x and y have to work together simultaneously to form a curve it slows WAY down. It even does this during CUT CONTOUR, if the contour has curves, that is. So: driver re-install? Laser Cut 5.3 setting that I've never heard of before? Something else?? Does anyone know any G Weike reps on this site that I could message directly? Thank you all in advance!!
    Re: G Weike 1290 Suddenly cutting at half speed in curves only: HELP! PLEASE!
    Does anyone have any suggestion??? This problem continues and is a huge issue for our Makerspace. I have contacted our rep from the company but they are slow to respond and don't seem to understand English fluently (at least our rep, anyway)
    Sep 2018
    83
    There are settings in lasercut 5.3 for dealing with acceleration rates - it sounds exactly like someone's messed with one of those, IMO. last time I was running a set of 1290s I experimented with said settings to try and improve cut quality, but ended up reverting them back to defaults, largely because it didn't achieve anything beneficial.
    Let me grab a copy of lasercut 5.3 to play with, so i can refresh my memory of where those settings are stored.
    Sep 2018
    83
    OK, I've managed to grab a copy of the software. It's been a couple of years since I last used it (and having been relatively spoiled by RDWorks, I'd forgotten how clunky it was).
    The settings you want to look at can be found in File>Machine Options, or you can jsut press Ctrl+J. My guess would be that someone's lowered the 'curve disperse' value - that's the setting that determines the accuracy of curves. There's a relatively coherent manual here that covers it briefly. I don't have a set of known good values for you to work from though, so you'll have to experiment with it a bit to get it right. Might be worth making the laser unavailable for a day or so while you get it sorted, with the note "Please do not sod about with the machine settings" on display to all users.
    Quote Originally Posted by GerryG View Post
    Wow! Thank you so much (just) for the response!!! I will go check this immediately and then check your 2nd(!) comment afterward and let you know!
    Ok: without knowing what the settings were before it is difficult to say what they SHOULD be, but the Corner acc. value under Machine options>Cut was set to 0.00. However, I tried many different values with no visible difference Another symptom to mention about the slow speed on diagonals and curves: the head moves in a jerky fashion where as before it moved smoothly/seamlessly around curves. Does this set off any flags for anyone (the jerky head movement in curves/whenever the x and y axes are moving simultaneously)?
    Quote Originally Posted by ChimeraLaser View Post
    Woops left out some info: Curves disperse value changes had no effect either :/
    Sep 2018
    83
    Corner acceleration doesn't govern how the machine deals with curves. That controls how the machine deals with entering and exiting sharp corners.
    The jerky head movement could be a variety of things - bad settings in the software, poor power supply to the stepper drivers, loss of belt tension and so forth. You didn't mention it before, which is why I solely chased down the curve dispersal setting.
    I suppose an easy way of testing whether it's a software or hardware issue would be to try a fresh installation of all software settings. In the C:/Lasercut53 folder, there's a file called syscfg.ini. Make a copy of it, and rename the copy something like OLDsyscfg.iniOLD, so the software doesn't try to read it. Open the non-renamed one in a text editor, and replace the contents with these default settings (as taken from a fresh installation):
    Code:
    [Technics]
    CreateTechnicsCodeNumber=6
    CreateTechnicsCodeDefaultMode=TECHNICS_LASERENGRAVE
    CreateTechnicsCodeDefaultMode_LINE=TECHNICS_UNKOWN
    CreateTechnicsCodeDefaultMode_IMAGE=TECHNICS_UNKOWN
    TechnicsDefaultType=0
    CreateTechnicsCodeDefaultMode_0=TECHNICS_LASERENGRAVE
    CreateTechnicsCodeDefaultMode_16711680=TECHNICS_LASERCUT
    CreateTechnicsCodeDefaultMode_255=TECHNICS_LASERENGRAVE
    [CreateTechnicsCode_0]
    CreateTechnicsCodeName=TECHNICS_LASERCUT
    [CreateTechnicsCode_1]
    CreateTechnicsCodeName=TECHNICS_LASERENGRAVE
    [CreateTechnicsCode_2]
    CreateTechnicsCodeName=TECHNICS_LASERGRADEENGRAVE
    [CreateTechnicsCode_3]
    CreateTechnicsCodeName=TECHNICS_LASERHITPOINT
    [CreateTechnicsCode_4]
    CreateTechnicsCodeName=TECHNICS_PENCUT
    [CreateTechnicsCode_5]
    CreateTechnicsCodeName=TECHNICS_KNIFECUT
    [CompanyInfo]
    TelPhone=
    SoftName=
    CompanyName=
    Http=
    [ApplicationSetting]
    OutPutWorkFile=1
    FlashDelayTime=10
    UserHighConfige=1
    ShowDebugWndMsg=0
    MainFaceType=0
    Mpc05PortNumber=1
    SelectOut=0
    ShowHandle=1
    BackColorRed=210
    BackColorGreen=255
    BackColorBlue=255
    PromptRevise=0
    OutputPLTPath=c:\Data.PLT
    LaserCutForSteel=0
    LimitWorkTimes=-1
    HideChineseButton=0
    TipPreWorkTime=0
    EcYXAxisType=0
    PrintMode=1
    [IMPORTFILE]
    PREFILEMODE=0
    NeedSuckPoint=0
    SuckPointTol=0.0
    ShowMinPointSize=0.0
    ShowMaxPointSize=100.0
    CENTERDATA=1
    UnitType=0
    SysPointDefaultSize=1.0
    SysDXFReadPointType=0
    SysDXFMaxLength=2000
    SysDXFMaxWidth=2000
    SysDXFMaxHeight=100
    DXFCalBasicPrecision=0.5
    DXFNeedCalDataBound=0
    MTextTrueTypeSpaceScale=0.25
    MTextShxSpaceScale=0.35
    AdjustDirect=0
    clockwise=1
    [MAPARRAY]
    MoveData=1
    [TableSetting]
    TableGridWidth=50
    TableGridHeight=50
    [MotionCard_0]
    MotionCard_Name=Step03Card
    [Step03Card_0]
    MotionCardName=Step-servo Co.,Ltd
    ValidIOLevel=0
    ValidLimitLevel=0
    LaserPowerMode=0
    LaserDefaultPulse=25000
    AxisPulseOutputMode=0
    AxisPulseOutputLogic=0
    ChecHomeIOType=0
    CardVer=LH
    OpenCardTipMsg=0
    GradeEngraveType=3
    LaserMaxPower=100
    CardMinVer=1
    LaserPowerTableNumber=20
    LaserPowerTable_0=0
    LaserPowerTable_5=5
    LaserPowerTable_10=10
    LaserPowerTable_15=15
    LaserPowerTable_20=20
    LaserPowerTable_25=25
    LaserPowerTable_30=30
    LaserPowerTable_35=35
    LaserPowerTable_40=40
    LaserPowerTable_45=45
    LaserPowerTable_50=50
    LaserPowerTable_55=55
    LaserPowerTable_60=60
    LaserPowerTable_65=65
    LaserPowerTable_70=70
    LaserPowerTable_75=75
    LaserPowerTable_80=80
    LaserPowerTable_85=85
    LaserPowerTable_90=90
    LaserPowerTable_95=95
    LaserPowerTable_100=100
    LaserLowerPulse=1000
    LaserLowerPower=0.1
    LaserPowerRepairPower=0
    TJCardNumber=1
    TJCARD_NUMBER_0=09110034
    YEncodeRate=10000.000000
    YSpdIncrease=300.000000
    XEncodeRate=10000.000000
    XSpdIncrease=300.000000
    YScaleCtrl=5.000000
    YIntegralCtrl=0.011500
    YDiffCtrl=0.002875
    XScaleCtrl=5.000000
    XIntegralCtrl=0.011500
    XDiffCtrl=0.002875
    YScaleCtrlii=5.000000
    XScaleCtrlii=5.000000
    YZero=0.000000
    XZero=0.000000
    YIntegralUpLev=100.000000
    XIntegralUpLev=100.000000
    DaLimY=0.500000
    DaLimX=0.500000
    WaterProtected=0
    ZMoveType=0
    CanContinueForEngrave=0
    SaveBreakTime=0.1
    [Step03LXCard_0]
    ValidIOLevel=0
    ValidLimitLevel=0
    LaserPowerMode=0
    AxisPulseOutputMode=1
    ChecHomeIOType=0
    CardVer=LX
    OpenCardTipMsg=0
    GradeEngraveType=3
    CardMinVer=1
    LaserMaxPower=100
    LaserPowerTable_0=0
    LaserPowerTable_5=5
    LaserLowerPulse=0
    LaserLowerPower=0
    TestCardNumber=1
    SupportArcMove=0
    SupportBezierMove=0
    ConAccStartSpeed=200.0
    MaxTrackNumInBuffer=500
    ChangLaserIONumber=0
    [Setup]
    ShortCutTip=LaserCut 5.3
    ExecuteFileName = LaserCut53.exe
    TipSetupChineseLanguage=1
    SetUpType=0
    AutoCADTip=AutoCAD
    CoreDrawTip=CorelDraw
    LaserCutTip=LaserCut53
    InstallPath=C:\LaserCut53
    [ONEAXIS_DEFAULT]
    CoordSystem_Name=??
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    OutputIOValue_1=-1
    OutputIOValue_2=-1
    SysAxisOID=1
    OnePulseMoveLength=0.00078125
    TableLength=150
    TableMinPosition=0
    TableMaxPosition=150
    OriginDirector=-1
    OriginPosition=0
    GoOriginSpeed=2
    OriginOffsetLen=1.5
    NeedRevise=0
    StartSpeed=0.5
    WorkAcc=100
    HandFastMoveSpeed = 15
    HandSlowMoveSpeed = 1
    [TWOAXIS_DEFAULT]
    CoordSystem_Name=??
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    OneAxisSysOID=0
    TwoAxisSysOID=1
    OneAxisOnePulseMoveLength=0.004843750000000
    TwoAxisOnePulseMoveLength=0.004843750000000
    OneAxisTableLength=1000.000000
    TwoAxisTableLength=600.000000
    OneAxisTableMinPosition=0.000000
    OneAxisTableMaxPosition=1000.000000
    TwoAxisTableMinPosition=0.000000
    TwoAxisTableMaxPosition=600.000000
    OneAxisOriginDirector=-1
    TwoAxisOriginDirector=1
    OneAxisOriginPosition=0.000000
    TwoAxisOriginPosition=600.000000
    OneAxisGoOriginSpeed=15.000000
    TwoAxisGoOriginSpeed=15.000000
    NeedRevise=0
    StartSpeed=10.000000
    WorkAcc=1200.000000
    SpaceSpeed=300.000000
    ConstantSpeed=10.000000
    HandFastMoveSpeed=200.000000
    HandSlowMoveSpeed=50.000000
    OneAxisBackLashLength=3
    TwoAxisBackLashLength=3
    [CoordSystem_0]
    CoordSystem_Type=TWOAXIS
    [CoordSystem_1]
    CoordSystem_Type=ONEAXIS
    [CoordSystem_2]
    CoordSystem_Type=THREEAXIS
    [TWOAXIS_0]
    CoordSystem_Name=???
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    OneAxisSysOID=0
    TwoAxisSysOID=1
    OneAxisOnePulseMoveLength=0.004800000000000
    TwoAxisOnePulseMoveLength=0.004800000000000
    OneAxisTableLength=1200.000000
    TwoAxisTableLength=900.000000
    OneAxisTableMaxPosition=1200.000000
    TwoAxisTableMaxPosition=900.000000
    OneAxisOriginDirector=1
    OneAxisOriginPosition=1200.000000
    TwoAxisOriginPosition=900.000000
    OneAxisGoOriginSpeed=120.000000
    TwoAxisGoOriginSpeed=120.000000
    OneAxisOriginOffsetLen=2
    TwoAxisOriginOffsetLen=2
    NeedRevise=0
    StartSpeed=5.000000
    WorkAcc=500.000000
    SpaceSpeed=150.000000
    ConstantSpeed=5.000000
    HandFastMoveSpeed=220.000000
    HandSlowMoveSpeed=200.000000
    OneAxisOverLapLength=0.000000
    WorkAcc2=700.000000
    SupportTwoXAxis=0
    TwoXAxisOffsetY2=0
    OneAxisOnePulseMoveLength2=0.00484375
    TwoXAxisPulseMoveLen=0.0062320000
    TwoXAxisReduceLen=70
    ParkStartSpeedScale=1.0
    ParkAccScale=1.0
    ParkSpeedScale=1.0
    WorkAccAcc=15000.000000
    SpaceAccAcc=15000.000000
    XAxisMaxChangeSpeed=20.000000
    YAxisMaxChangeSpeed=20.000000
    SupportTwoLaser=0
    TwoLaserSpaceLength=0.000000
    [ONEAXIS_1]
    CoordSystem_Name=??
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    SysAxisOID=2
    OnePulseMoveLength=0.001250000000000
    TableLength=350.000000
    TableMaxPosition=350.000000
    OriginDirector=1
    OriginPosition=350.000000
    GoOriginSpeed=10.000000
    OriginOffsetLen=35.000000
    NeedRevise=0
    WorkAcc=50.000000
    HandFastMoveSpeed =12.000000
    HandSlowMoveSpeed =11.000000
    StartSpeed=2.000000
    SpaceSpeed=10.000000
    WorkAccAcc=20000.000000
    SpaceAccAcc=80000.000000
    AxisMaxChangeSpeed=30.000000
    [HandMoveCoordSystem_DEFAULT]
    HandMoveAxis1Increase=-1
    HandMoveAxis1Reduce=-1
    HandMoveAxis2Increase=-1
    HandMoveAxis2Reduce=-1
    HandMoveAxis3Increase=-1
    HandMoveAxis3Reduce=-1
    HandMoveSpeed=-1
    HandMoveStepOrContinue=-1
    [Technics_Laser_Data]
    ExportRows=1
    ExportColumns=1
    ExportRowSpace=0.00000
    ExportColumnSpace=0.00000
    ExportRowCW=0.00000
    ExportColumnCW=0.00000
    DrawArrayDataType=1
    LogicOrgPostionType=1
    ArrayExportOrder=1
    ArrayExportXOrder=1
    ArrayExportYOrder=1
    AtOnceExport=1
    OutputTimes=1
    DelayTime=0
    FeedLength=0.000000
    FeedSpeed=5.000000
    MachineHasWorkMinute=681
    FeedDelayTime=0
    ChangeSerialNo=0
    OuputLayerOrderType=1
    IsTwoLaserWorking=0
    [LaserSimulateSpeedScale]
    SimulateSpeedScaleNumber = 3
    SimulateSpeed0_Min=0
    SimulateSpeed0_Max=100
    SimulateSpeed0_Scale=1
    SimulateSpeed1_Min=100
    SimulateSpeed1_Max=500
    SimulateSpeed1_Scale=1
    SimulateSpeed2_Min=500
    SimulateSpeed2_Max=5000
    SimulateSpeed2_Scale=1
    [MACHINE_MODIFYCFG]
    LASER_MODIFYCFG_SAVEPASSWORD=1
    LASER_MODIFYCFG_PASSWORD=0
    [RUNTIMECFG]
    OneCoordSys_ONEAXIS_PULSE=1600
    OneCoordSys_ONEAXIS_LENGTH=2.000000
    TwoCoordSys_ONEAXIS_PULSE=5000
    TwoCoordSys_ONEAXIS_LENGTH=24
    TwoCoordSys_TWOAXIS_PULSE=5000
    TwoCoordSys_TWOAXIS_LENGTH=24
    IMPORTFILE_CENTERDATA=1
    CombineLine_TOL=1.000000
    SmoothLine_JB=2
    AdjustStartPt=0
    NeedPartWorkCtrol=0
    StartWorkDelayTime=0
    NeedControlMainAxis=0
    OverWorkDelayTime=0
    TwoCoordSys_TWOAXIS_PULSE2=6400
    TwoCoordSys_TWOAXIS_LENGTH2=50
    [ResourceManager]
    CreateDefaultLanguageFile=0
    [GEOMETRY]
    SupportARC=0
    [FileFormatCfg_dst]
    MaxCurveNumber=1500
    MustCloseBlock=1
    SmoothTol=0.500000
    [FileFormatCfg_plt]
    MaxCurveNumber=1500
    DrawPLTUnit=1016.000000
    [FileFormatCfg_ai]
    MaxCurveNumber=1400
    [FileFormatCfg_eps]
    MaxCurveNumber=1400
    [FileFormatCfg_bmp]
    MaxCurveNumber=1400
    [Laser]
    AutoSimulateSpeed=8
    [DataCheck]
    overlap=1
    selfinter=0
    close=0
    intersection=0
    overlaptol=0.01
    lineinterTol=0
    interwithleadline=1
    [COREDRAW_CAD]
    MustCalSecondFile=1
    [OFFSETCFG]
    OffsetDist=5.000000
    OffsetType=0
    OffsetTolerance=0.200000
    MinPointNum=6
    Offset=0
    connect=0
    [LASERCAD]
    GetEntitiesType=0
    [MachineControl]
    MachineMotionCardNumber = 1
    MachineAXISNumber = 3
    MachineInputIONumber=17
    MachineOutputIONumber=10
    CoordSystemNumber =2
    MainCoordSystemID = 0
    FeedCoordSystemOID=1
    TestMoveLength=50.000000
    TestLaserPower=10.000000
    StartCmdDoPause=0
    MachineInputIODelay=3
    ClickLaserTime=0.1
    ApplicationLimitType=10
    TestOpenLaserType=0
    ThreadWorkMode=1
    PerWorkTimesApplyHardHome=0
    LoopAppylHomeType=1
    AtOnceExport=0
    ClipBoxPower=40.000000
    ClipBoxOffsetLen=2.000000
    ClipBoxSpeed=25.000000
    RunBoxConnerAcc=100
    NeedAlign=0
    PerWorkMustGoLogicHome=1
    AfterGoHomeToLogicHome=0
    TestIsSlowSpeed=0
    ClipBoxPower2=40.000000
    RunMustDatum=0
    AlignMachineZPos=0.000000
    LogicOrgPositionX=636.987500
    LogicOrgPositionY=455.962500
    NeedOutput530=0
    SupportSplitBlockOutPut=0
    ZAxisForLaserFocus=0
    FeedAxisGoHome=0
    NeedContinueTipForBlock=0
    [MotionAxis_0]
    MotionCard_Index=0
    MotionCard_axisOID=4
    [MotionAxis_1]
    MotionCard_Index=0
    MotionCard_axisOID=3
    [MotionAxis_2]
    MotionCard_Index=0
    MotionCard_axisOID=2
    [MotionInputIO_0];X?
    MotionCard_Index=0
    MotionCard_InputIOOID=38
    [MotionInputIO_1];X?
    MotionCard_Index=0
    MotionCard_InputIOOID=46
    [MotionInputIO_2];Y?
    MotionCard_Index=0
    MotionCard_InputIOOID=40
    [MotionInputIO_3];Y?
    MotionCard_Index=0
    MotionCard_InputIOOID=36
    [MotionInputIO_4];??
    MotionCard_Index=0
    MotionCard_InputIOOID=44
    [MotionInputIO_5];??
    MotionCard_Index=0
    MotionCard_InputIOOID=8
    [MotionInputIO_6];??
    MotionCard_Index=0
    MotionCard_InputIOOID=12
    [MotionInputIO_7];????
    MotionCard_Index=0
    [MotionInputIO_8];??/??
    MotionCard_Index=0
    [MotionInputIO_9];Z?
    MotionCard_Index=0
    MotionCard_InputIOOID=29
    [MotionInputIO_10];Z?
    MotionCard_Index=0
    MotionCard_InputIOOID=31
    [MotionInputIO_11];???
    MotionCard_Index=0
    MotionCard_InputIOOID=10
    [MotionInputIO_12];???
    MotionCard_Index=0
    MotionCard_InputIOOID=42
    [MotionInputIO_13];????
    MotionCard_Index=0
    MotionCard_InputIOOID=27
    [MotionInputIO_14];XYZ??
    MotionCard_Index=0
    MotionCard_InputIOOID=-1
    [MotionInputIO_15];Z???
    MotionCard_Index=0
    [MotionInputIO_16];????
    MotionCard_Index=0
    [HandMoveCoordSystem_0]
    HandMoveAxis1Increase=0
    HandMoveAxis1Reduce=1
    HandMoveAxis2Increase=2
    HandMoveAxis2Reduce=3
    HandMoveSpeed=7
    HandMoveStepOrContinue=8
    [HandMoveCoordSystem_1]
    HandMoveAxis1Increase=9
    HandMoveAxis1Reduce=10
    HandMoveSpeed=7
    [MotionOutputIO_0];????
    MotionCard_Index=0
    MotionCard_OutputIOOID=15
    [MotionOutputIO_1];????
    MotionCard_Index=0
    MotionCard_OutputIOOID=18
    [MotionOutputIO_2];????
    MotionCard_Index=0
    MotionCard_OutputIOOID=150
    [MotionOutputIO_3];??????????
    MotionCard_Index=0
    MotionCard_OutputIOOID=-1
    [MotionOutputIO_4];??
    MotionCard_Index=0
    [MotionOutputIO_5];?????
    MotionCard_Index=0
    [MotionOutputIO_6];
    MotionCard_Index=0
    [MotionOutputIO_7];??
    MotionCard_Index=0
    [MotionOutputIO_8];??
    MotionCard_Index=0
    [MotionOutputIO_9]
    MotionCard_Index=0
    [TECHNICS_LASERCUT]
    CreateTechnicsCodeName=????
    TechnicsCfgType=0
    LaserCutCoordSysOID=0
    LaserCutConnerPower=15.000000
    LaserCutWorkPower=16.000000
    LaserCutFrequency=20000
    LaserCutOptimizePathType=1
    LaserCutInnerToOuter=1
    LaserCutDownToUpper=0
    LaserCutBlockHeight=150.000000
    LaserCutAutoSetPathDir=0
    LaserCutCicleMinSegNumber=36
    LaserCutDisperseLength=0.020000
    LaserCutCloseGapLength=0.000000
    LaserCutOverlapLength=0.000000
    LaserCutAdjustForClose=0
    LaserCutQXEnterLength=0.000000
    LaserCutDelayMoveTime=0.000000
    LaserCutOpenLaserDelayTime=0.000000
    LaserCutCloseLaserDelayTime=0.000000
    LaserCutOneAxisBackLashLength=0.000000
    LaserCutTwoAxisBackLashLength=0.030000
    LaserCutBlowGasType=2
    LaserCutAheadBlowGasTimes=0.000000
    LaserCutNoCloseGasTimes=0.000000
    LaserCutSpeed=120.000000
    LaserCutGWAcc=300.000000
    LaserCutCircleSpeedNum=1
    LaserCutCircleSpeed0_MinR=0.000000
    LaserCutCircleSpeed0_MaxR=3.000000
    LaserCutCircleSpeed0_Speed=20.000000
    LaserCutCircleSpeed1_MinR=0.550000
    LaserCutCircleSpeed1_MaxR=1.050000
    LaserCutCircleSpeed1_Speed=15.000000
    LaserCutCircleSpeed2_MinR=1.050000
    LaserCutCircleSpeed2_MaxR=1.550000
    LaserCutCircleSpeed2_Speed=25.000000
    LaserCutCircleSpeed3_MinR=1.550000
    LaserCutCircleSpeed3_MaxR=2.050000
    LaserCutCircleSpeed3_Speed=30.000000
    LaserCutCircleSpeed4_MinR=2.050000
    LaserCutCircleSpeed4_MaxR=3.050000
    LaserCutCircleSpeed4_Speed=35.000000
    LaserCutCircleSpeed5_MinR=3.050000
    LaserCutCircleSpeed5_MaxR=4.050000
    LaserCutCircleSpeed5_Speed=40.000000
    LaserCutGWTime=0.010000
    LaserCutTrackSize=100
    LaserCutMaxSpeed=400.000000
    LaserCutConnerPower2=30.000000
    LaserCutWorkPower2=50.000000
    LaserCutInnerToOuter2=0
    LaserCutStartPosType=0
    LaserCutDelayTimeAfterCloseLaser=0.000000
    LaserCutBackLashAddSpaceLength=8.000000
    LaserCutLineLength=0.000000
    SpaceCutLineLength=0.000000
    bSpaceLineFirst=0
    LaserCutAdjustMove=0
    LaserCutAdjustMoveDelay=0.000000
    LaserCutUpLen=0.000000
    LaserCutDisperseMinLength=0.02
    LaserCutOpenGZDelayTime=0.000000
    LaserCutSpeedScale1=1.0
    LaserCutSpeedScale2=1.0
    LaserCutSpeedScale3=1.0
    LaserCutSpeedScale4=1.0
    LaserCutSpeedScale5=1.0
    LaserCutSpeedScale6=1.0
    LaserCutSpeedScale7=1.0
    LaserCutSpeedScale8=1.0
    AdjustStartPointToConner=0
    SplitCircleForBY=0
    AdjustMoveType=0
    WaitInputIODelayTime=5
    RepeatOpenLaserTimes=0
    SupportAIOutput=0
    LaserHitPointOptimizePathType=1
    LaserHitPointInnerToOuter=1
    LaserHitPointDownToUpper=0
    LaserHitPointBlockHeight=200
    LaserHitPointAutoSetPathDir=1
    LaserHitPointStartPosType=0
    [TECHNICS_LASERENGRAVE]
    TechnicsCfgType=0
    LaserEngraveCoordSysOID=0
    LaserEngravePower=30.000000
    LaserEngraveFrequency=20000
    LaserEngraveSpeed=600.000000
    LaserEngraveBlowGasType=1
    LaserEngraveFillCircleR=2.500000
    LaserEngraveFillCircleSpace=2.500000
    LaserEngraveFillCircle=0
    LaserEngraveTwoDirector=1
    LaserEngraveScanStepLen=0.500000
    LaserEngraveCfgNumber=5
    LaserEngraveMinSpeed_0=0.000000
    LaserEngraveMaxSpeed_0=250.000000
    LaserEngraveBufferLen_0=25.000000
    LaserEngraveChangeDirGap_0=-0.100000
    LaserEngraveStartVel_0=25.000000
    LaserEngraveAcc_0=10000.000000
    LaserEngraveYSpeed_0=10.000000
    LaserEngraveYAcc_0=1000.000000
    LaserEngraveSFOffsetX_0=0.050000
    LaserEngraveSFOffsetY_0=0.000000
    LaserEngraveExpandPenWidth=0
    LaserEngraveExpandPenWidthScale=15.000000
    LaserEngraveFillCircleType=0
    LaserEngraveMaxSpeed=1000.000000
    LaserEngravePower2=60.000000
    LaserEngraveScanDirector=0
    LaserEngraveMinSpeed_1=250.000000
    LaserEngraveMaxSpeed_1=350.000000
    LaserEngraveBufferLen_1=25.000000
    LaserEngraveChangeDirGap_1=-0.150000
    LaserEngraveStartVel_1=25.000000
    LaserEngraveAcc_1=10000.000000
    LaserEngraveYSpeed_1=10.000000
    LaserEngraveYAcc_1=1000.000000
    LaserEngraveSFOffsetX_1=0.075000
    LaserEngraveSFOffsetY_1=0.000000
    LaserEngraveMinSpeed_2=350.000000
    LaserEngraveMaxSpeed_2=450.000000
    LaserEngraveBufferLen_2=25.000000
    LaserEngraveChangeDirGap_2=-0.200000
    LaserEngraveStartVel_2=25.000000
    LaserEngraveAcc_2=10000.000000
    LaserEngraveYSpeed_2=10.000000
    LaserEngraveYAcc_2=1000.000000
    LaserEngraveSFOffsetX_2=0.100000
    LaserEngraveSFOffsetY_2=0.000000
    LaserEngraveMinSpeed_3=450.000000
    LaserEngraveMaxSpeed_3=550.000000
    LaserEngraveBufferLen_3=25.000000
    LaserEngraveChangeDirGap_3=-0.250000
    LaserEngraveStartVel_3=25.000000
    LaserEngraveAcc_3=10000.000000
    LaserEngraveYSpeed_3=10.000000
    LaserEngraveYAcc_3=1000.000000
    LaserEngraveSFOffsetX_3=0.125000
    LaserEngraveSFOffsetY_3=0.000000
    LaserEngraveMinSpeed_4=550.000000
    LaserEngraveMaxSpeed_4=2000.000000
    LaserEngraveBufferLen_4=25.000000
    LaserEngraveChangeDirGap_4=-0.300000
    LaserEngraveStartVel_4=25.000000
    LaserEngraveAcc_4=10000.000000
    LaserEngraveYSpeed_4=10.000000
    LaserEngraveYAcc_4=1000.000000
    LaserEngraveSFOffsetX_4=0.150000
    LaserEngraveSFOffsetY_4=0.000000
    LaserEngraveMinSpeed_5=550.000000
    LaserEngraveMaxSpeed_5=2000.000000
    LaserEngraveBufferLen_5=25.000000
    LaserEngraveChangeDirGap_5=-0.320000
    LaserEngraveStartVel_5=45.000000
    LaserEngraveAcc_5=10000.000000
    LaserEngraveYSpeed_5=10.000000
    LaserEngraveYAcc_5=1000.000000
    LaserEngraveSFOffsetX_5=0.160000
    LaserEngraveSFOffsetY_5=0.000000
    LaserEngraveMinSpeed_6=650.000000
    LaserEngraveMaxSpeed_6=750.000000
    LaserEngraveBufferLen_6=25.000000
    LaserEngraveChangeDirGap_6=0.000000
    LaserEngraveStartVel_6=45.000000
    LaserEngraveAcc_6=6000.000000
    LaserEngraveYSpeed_6=10.000000
    LaserEngraveYAcc_6=100.000000
    LaserEngraveSFOffsetX_6=0.000000
    LaserEngraveSFOffsetY_6=0.000000
    LaserEngraveMinSpeed_7=750.000000
    LaserEngraveMaxSpeed_7=850.000000
    LaserEngraveBufferLen_7=25.000000
    LaserEngraveChangeDirGap_7=0.000000
    LaserEngraveStartVel_7=45.000000
    LaserEngraveAcc_7=6000.000000
    LaserEngraveYSpeed_7=10.000000
    LaserEngraveYAcc_7=100.000000
    LaserEngraveSFOffsetX_7=0.000000
    LaserEngraveSFOffsetY_7=0.000000
    LaserEngraveMinSpeed_8=850.000000
    LaserEngraveMaxSpeed_8=1000.000000
    LaserEngraveBufferLen_8=25.000000
    LaserEngraveChangeDirGap_8=0.000000
    LaserEngraveStartVel_8=45.000000
    LaserEngraveAcc_8=6000.000000
    LaserEngraveYSpeed_8=10.000000
    LaserEngraveYAcc_8=100.000000
    LaserEngraveSFOffsetX_8=0.000000
    LaserEngraveSFOffsetY_8=0.000000
    [TECHNICS_LASERHITPOINT]
    TechnicsCfgType=0
    LaserHitPointCoordSysOID=0
    LaserHitPointWorkPower=18.000000
    LaserHitPointFrequency=20000
    LaserHitPointBlockHeight=150.000000
    LaserHitPointDisperseLength=0.050000
    LaserHitPointType=0
    LaserHitPointGapLength=2.000000
    LaserHitPointDelayTime=0.100000
    LaserHitPointBlowGasType=1
    LaserHitPointWorkPower2=50.000000
    LaserHitPointOpenLaserDelayTime=0.000000
    [TECHNICS_LASERGRADEENGRAVE]
    CreateTechnicsCodeName=??????
    TechnicsCfgType=0
    LaserGradeEngraveCoordSysOID=0
    LaserGradeEngravePower=95.000000
    LaserGradeEngraveStartPower=30.000000
    LaserGradeEngraveFrequency=20000
    LaserGradeEngraveSpeed=150.000000
    LaserGradeEngraveBlowGasType=1
    LaserGradeEngraveTwoDirector=1
    LaserGradeEngraveScanStepLen=0.100000
    LaserGradeEngraveGradeWidth=1.500000
    LaserGradeEngraveGradeNumber=32
    LaserGradeEngraveNeedRepairGrade=0
    LaserGradeEngraveStartRepairGrade=0.200000
    LaserGradeEngraveCfgNumber=0
    LaserGradeEngraveMinSpeed_0=0.000000
    LaserGradeEngraveMaxSpeed_0=150.000000
    LaserGradeEngraveBufferLen_0=25.000000
    LaserGradeEngraveChangeDirGap_0=0.000000
    LaserGradeEngraveStartVel_0=45.000000
    LaserGradeEngraveAcc_0=6000.000000
    LaserGradeEngraveYSpeed_0=10.000000
    LaserGradeEngraveYAcc_0=100.000000
    LaserGradeEngraveSFOffsetX_0=0.000000
    LaserGradeEngraveSFOffsetY_0=0.000000
    LaserGradeEngraveMaxSpeed=1000.000000
    LaserGradeEngraveScanDirector=0
    LaserGradeEngraveMinSpeed_1=150.000000
    LaserGradeEngraveMaxSpeed_1=250.000000
    LaserGradeEngraveBufferLen_1=25.000000
    LaserGradeEngraveChangeDirGap_1=0.000000
    LaserGradeEngraveStartVel_1=45.000000
    LaserGradeEngraveAcc_1=6000.000000
    LaserGradeEngraveYSpeed_1=10.000000
    LaserGradeEngraveYAcc_1=100.000000
    LaserGradeEngraveSFOffsetX_1=0.000000
    LaserGradeEngraveSFOffsetY_1=0.000000
    LaserGradeEngraveMinSpeed_2=250.000000
    LaserGradeEngraveMaxSpeed_2=350.000000
    LaserGradeEngraveBufferLen_2=25.000000
    LaserGradeEngraveChangeDirGap_2=0.000000
    LaserGradeEngraveStartVel_2=45.000000
    LaserGradeEngraveAcc_2=6000.000000
    LaserGradeEngraveYSpeed_2=10.000000
    LaserGradeEngraveYAcc_2=100.000000
    LaserGradeEngraveSFOffsetX_2=0.000000
    LaserGradeEngraveSFOffsetY_2=0.000000
    LaserGradeEngraveMinSpeed_3=350.000000
    LaserGradeEngraveMaxSpeed_3=450.000000
    LaserGradeEngraveBufferLen_3=25.000000
    LaserGradeEngraveChangeDirGap_3=0.000000
    LaserGradeEngraveStartVel_3=45.000000
    LaserGradeEngraveAcc_3=6000.000000
    LaserGradeEngraveYSpeed_3=10.000000
    LaserGradeEngraveYAcc_3=100.000000
    LaserGradeEngraveSFOffsetX_3=0.000000
    LaserGradeEngraveSFOffsetY_3=0.000000
    LaserGradeEngraveMinSpeed_4=450.000000
    LaserGradeEngraveMaxSpeed_4=550.000000
    LaserGradeEngraveBufferLen_4=25.000000
    LaserGradeEngraveChangeDirGap_4=0.000000
    LaserGradeEngraveStartVel_4=45.000000
    LaserGradeEngraveAcc_4=6000.000000
    LaserGradeEngraveYSpeed_4=10.000000
    LaserGradeEngraveYAcc_4=100.000000
    LaserGradeEngraveSFOffsetX_4=0.000000
    LaserGradeEngraveSFOffsetY_4=0.000000
    [TechnicsOrign]
    StopPosition=3
    ResponseEvent=1
    [textdefault]
    FontHeight=22
    FontSpace=2
    text=117
    FontName=Arial Black
    IsTrueType=1
    mainShxName=txt
    subShxName=NULL
    [MainAxisSpeed]
    MainAxisDefaultIndex=0
    [FileFormatCfg_ECP]
    MaxCurveNumber=1500
    [LayerManager]
    HideNoOutputLayer=0
    ApplyAllLayerAttrib=1
    [FileFormatCfg_map]
    MaxCurveNumber=1500
    [TECHNICS_PENCUT]
    TechnicsCfgType=0
    PenCutCoordSysOID=0
    PenCutOptimizePathType=1
    PenCutInnerToOuter=1
    PenCutDownToUpper=0
    PenCutBlockHeight=150.000000
    PenCutAutoSetPathDir=1
    PenCutCicleMinSegNumber=36
    PenCutDisperseLength=0.050000
    PenCutCloseGapLength=0.000000
    PenCutOverlapLength=0.000000
    PenCutAdjustForClose=0
    PenCutQXEnterLength=1.000000
    PenCutDelayDownTime=0.000000
    PenCutDelayUpTime=0.000000
    PenCutOneAxisBackLashLength=0.000000
    PenCutTwoAxisBackLashLength=0.000000
    PenCutSpeed=75.000000
    PenCutGWAcc=3000.000000
    PenCutGWTime=0.010000
    PenCutTrackSize=100
    PenCutOffsetX=0.000000
    PenCutOffsetY=0.000000
    PenCutCtrolMode=0
    PenCutCircleSpeedNum=0
    [TECHNICS_KNIFECUT]
    KnifeCutDownSpeed=20
    [TechcisMode]
    SupportMachineEngrave=0
    [CreateTextCmd]
    SupportReverse=0
    Convert2Curve=1
    [FileFormatCfg_dxf]
    MaxCurveNumber=1500
    [ArrayCopyCmd]
    SupportSPath=1
    CenterAlign=0
    [DaHen]
    NeedSetChangePower=0
    StartPower=0
    ChangePowerPoint=0
    ChangeFrq=0
    Save the file, and try the laser out.
    For a text editor, I'd recommend notepad++ - windows default notepad is not very good, and handles returns and linefeeds poorly.
    If that doesn't change anything, then there's a chance that someone's messed with the hardware, or that you've got a component failing somewhere.
    Code:
    [Technics]
    [CompanyInfo]
    TelPhone=
    SoftName=
    CompanyName=
    Http=
    OutPutWorkFile=1
    FlashDelayTime=10
    UserHighConfige=1
    ShowDebugWndMsg=0
    MainFaceType=0
    Mpc05PortNumber=1
    SelectOut=0
    ShowHandle=1
    BackColorRed=210
    BackColorGreen=255
    BackColorBlue=255
    PromptRevise=0
    LaserCutForSteel=0
    LimitWorkTimes=-1
    HideChineseButton=0
    TipPreWorkTime=0
    EcYXAxisType=0
    PrintMode=1
    [IMPORTFILE]
    PREFILEMODE=0
    NeedSuckPoint=0
    SuckPointTol=0.0
    CENTERDATA=1
    UnitType=0
    SysDXFMaxWidth=2000
    SysDXFMaxHeight=100
    AdjustDirect=0
    clockwise=1
    [MAPARRAY]
    MoveData=1
    [TableSetting]
    TableGridWidth=50
    TableGridHeight=50
    [MotionCard_0]
    [Step03Card_0]
    ValidIOLevel=0
    ValidLimitLevel=0
    LaserPowerMode=0
    ChecHomeIOType=0
    CardVer=LH
    OpenCardTipMsg=0
    GradeEngraveType=3
    LaserMaxPower=100
    CardMinVer=1
    LaserPowerTable_0=0
    LaserPowerTable_5=5
    LaserLowerPower=0.1
    TJCardNumber=1
    YScaleCtrl=5.000000
    YDiffCtrl=0.002875
    XScaleCtrl=5.000000
    XDiffCtrl=0.002875
    YZero=0.000000
    XZero=0.000000
    DaLimY=0.500000
    DaLimX=0.500000
    WaterProtected=0
    ZMoveType=0
    SaveBreakTime=0.1
    [Step03LXCard_0]
    ValidIOLevel=0
    ValidLimitLevel=0
    LaserPowerMode=0
    ChecHomeIOType=0
    CardVer=LX
    OpenCardTipMsg=0
    GradeEngraveType=3
    CardMinVer=1
    LaserMaxPower=100
    LaserPowerTable_0=0
    LaserPowerTable_5=5
    LaserLowerPulse=0
    LaserLowerPower=0
    TestCardNumber=1
    SupportArcMove=0
    SupportBezierMove=0
    [Setup]
    SetUpType=0
    AutoCADTip=AutoCAD
    [ONEAXIS_DEFAULT]
    CoordSystem_Name=??
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    OutputIOValue_1=-1
    OutputIOValue_2=-1
    SysAxisOID=1
    TableLength=150
    TableMinPosition=0
    OriginDirector=-1
    OriginPosition=0
    GoOriginSpeed=2
    OriginOffsetLen=1.5
    NeedRevise=0
    StartSpeed=0.5
    WorkAcc=100
    [TWOAXIS_DEFAULT]
    CoordSystem_Name=??
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    OneAxisSysOID=0
    TwoAxisSysOID=1
    NeedRevise=0
    WorkAcc=1200.000000
    [CoordSystem_0]
    [CoordSystem_1]
    [CoordSystem_2]
    [TWOAXIS_0]
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    OneAxisSysOID=0
    TwoAxisSysOID=1
    NeedRevise=0
    StartSpeed=5.000000
    WorkAcc=500.000000
    WorkAcc2=700.000000
    SupportTwoXAxis=0
    TwoXAxisOffsetY2=0
    ParkAccScale=1.0
    ParkSpeedScale=1.0
    SupportTwoLaser=0
    [ONEAXIS_1]
    CoordSystem_Name=??
    SysOutputIOOID_1=-1
    SysOutputIOOID_2=-1
    SysAxisOID=2
    OriginDirector=1
    NeedRevise=0
    WorkAcc=50.000000
    StartSpeed=2.000000
    HandMoveSpeed=-1
    ExportRows=1
    ExportColumns=1
    ExportRowCW=0.00000
    DrawArrayDataType=1
    ArrayExportOrder=1
    ArrayExportXOrder=1
    ArrayExportYOrder=1
    AtOnceExport=1
    OutputTimes=1
    DelayTime=0
    FeedLength=0.000000
    FeedSpeed=5.000000
    FeedDelayTime=0
    ChangeSerialNo=0
    IsTwoLaserWorking=0
    [MACHINE_MODIFYCFG]
    [RUNTIMECFG]
    SmoothLine_JB=2
    AdjustStartPt=0
    NeedPartWorkCtrol=0
    OverWorkDelayTime=0
    [ResourceManager]
    [GEOMETRY]
    SupportARC=0
    [FileFormatCfg_dst]
    MaxCurveNumber=1500
    MustCloseBlock=1
    SmoothTol=0.500000
    [FileFormatCfg_plt]
    MaxCurveNumber=1500
    [FileFormatCfg_ai]
    MaxCurveNumber=1400
    [FileFormatCfg_eps]
    MaxCurveNumber=1400
    [FileFormatCfg_bmp]
    MaxCurveNumber=1400
    [Laser]
    AutoSimulateSpeed=8
    [DataCheck]
    overlap=1
    selfinter=0
    close=0
    intersection=0
    overlaptol=0.01
    lineinterTol=0
    interwithleadline=1
    [COREDRAW_CAD]
    MustCalSecondFile=1
    [OFFSETCFG]
    OffsetDist=5.000000
    OffsetType=0
    MinPointNum=6
    Offset=0
    connect=0
    [LASERCAD]
    GetEntitiesType=0
    [MachineControl]
    StartCmdDoPause=0
    ClickLaserTime=0.1
    TestOpenLaserType=0
    ThreadWorkMode=1
    LoopAppylHomeType=1
    AtOnceExport=0
    RunBoxConnerAcc=100
    NeedAlign=0
    TestIsSlowSpeed=0
    RunMustDatum=0
    NeedOutput530=0
    FeedAxisGoHome=0
    [MotionAxis_0]
    MotionCard_Index=0
    [MotionAxis_1]
    MotionCard_Index=0
    [MotionAxis_2]
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    HandMoveSpeed=7
    HandMoveSpeed=7
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    [MotionOutputIO_6];
    MotionCard_Index=0
    MotionCard_Index=0
    MotionCard_Index=0
    [MotionOutputIO_9]
    MotionCard_Index=0
    [TECHNICS_LASERCUT]
    TechnicsCfgType=0
    bSpaceLineFirst=0
    SplitCircleForBY=0
    AdjustMoveType=0
    SupportAIOutput=0
    TechnicsCfgType=0
    TechnicsCfgType=0
    LaserHitPointType=0
    TechnicsCfgType=0
    [TechnicsOrign]
    StopPosition=3
    ResponseEvent=1
    [textdefault]
    FontHeight=22
    FontSpace=2
    text=117
    IsTrueType=1
    mainShxName=txt
    subShxName=NULL
    [MainAxisSpeed]
    [FileFormatCfg_ECP]
    MaxCurveNumber=1500
    [LayerManager]
    HideNoOutputLayer=0
    [FileFormatCfg_map]
    MaxCurveNumber=1500
    [TECHNICS_PENCUT]
    TechnicsCfgType=0
    PenCutCoordSysOID=0
    PenCutDownToUpper=0
    PenCutTrackSize=100
    PenCutCtrolMode=0
    [TECHNICS_KNIFECUT]
    [TechcisMode]
    [CreateTextCmd]
    SupportReverse=0
    Convert2Curve=1
    [FileFormatCfg_dxf]
    MaxCurveNumber=1500
    [ArrayCopyCmd]
    SupportSPath=1
    CenterAlign=0
    [DaHen]
    StartPower=0
    ChangePowerPoint=0
    ChangeFrq=0
    Thank you again--I apologize for the incomplete info in the beginning. I will try this solution as soon as I can get help from someone more computer savvy than I and I will get back to you.
    Sep 2018
    83
    No need to apologise.
    I should have added, if this doesn't work, then it may be worth progressing to the next step and re-installing the software. If *that* doesn't work, then you're looking at hardware fixes.
    GerryG!!! Your re-install worked! This completely solved the issue! Thank you so much! Please let me know if you ever need anything--who knows, I may be able to help you with something, some day -- Kevin
    Sep 2018
    83
    Not a problem. Happy to have helped
  1. Replies: 4
    Last Post: 09-17-2021, 07:22 AM
  2. Intermittent error with otherwise functioning laser cutter (G Weike 1290, 100W RECI)
    By Basecamp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2014, 11:02 AM
  3. laser cutting machine MT-L1280/1290/1212/1480
    By mornlift in forum News Announcements
    Last Post: 04-18-2013, 10:34 AM
  4. Is there a way to speed up my weike 1290?
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-09-2013, 06:09 AM
  5. efficiently cutting curves
    By endgrainguy in forum G-Code Programing
    Last Post: 06-06-2008, 01:20 PM
