585,981 active members*
4,288 visitors online*
Results 1 to 11 of 11
    Aug 2014
    10
    Calibrating my machine
    My first machine was belt driven and mach3 would calibrate. I changed to ball screws and i have been unable to calibrate. Any suggestions?
    Nov 2012
    1267
    Re: Calibrating my machine
    By "calibration" do you mean finding the correct steps-per-unit values?
    Aug 2014
    10
    Yes
    Nov 2012
    1267
    Those are pretty easy to calculate without using Mach3's wizard. Post some information about your machine:
    - ball screw thread pitch
    - ball screw number of starts
    - stepper motor degrees per step
    - stepper driver number of microsteps per step
    - any gearing between the stepper motor and the ball screw.
    Aug 2014
    10
    SFU1605 RM1605 1605 Ball Screw
    Pitch is 5
    Start is 5
    Nema 23 57mm Stepper Motor High Torque
    200 steps
    Nov 2012
    1267
    You did not say what your microstepping is, but let's assume it's 8.
    Then your steps-per-millimeter would be:
    200*8/5=320.
    If you are using inches, multiply 320 by 25.4.
    P. S.
    According to the Internet, SFU1605 is single-start, not 5-start. So it has 5mm thread pitch and 5mm lead.
    Aug 2014
    10
    16
    Nov 2012
    1267
    Then 200*16/5=640 steps per mm.
    Aug 2014
    10
    Thank you for your help. When i am twicking movement when movement is more than requested do i add or substrat ?
    Aug 2014
    10
    Thank you.
    Nov 2012
    1267
    If your ball screw is accurate (and it probably is), then the calibration should be spot on. But if you do need to tweak it, then BIGGER steps-per-unit means BIGGER movement.
    edited. sorry, got it wrong the first time.
  1. Calibrating X and Y axis on 4060 China laser engraving/cutting machine.
    By doken in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-17-2021, 09:31 AM
  2. Calibrating X and Y axis on 5030 China laser engraving/cutting machine
    By raipe in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-22-2016, 01:31 PM
  3. Calibrating a machine
    By Down&Dirty in forum Waterjet General Topics
    Last Post: 03-17-2011, 01:44 AM
  4. Calibrating
    By ikkedus in forum Hobby Discussion
    Last Post: 04-23-2004, 04:57 PM
