585,927 active members*
3,876 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > i just bought from amazon Changzhou Longs-Motor?
    Dec 2009
    36
    I just bought from Amazon Changzhou Longs-Motor 4 axis kit, with BOB and 4- DM542A drivers; no wiring instructions. I have seen really poor pictures of the wiring diagram and probably can figure that out, just not sure about the switches. A good wire diagram and switch detail would be greatly appreciated. Thank you in advance!
    Mar 2007
    2083
    Re: i just bought from amazon Changzhou Longs-Motor?
    is your breakout board like this ?
    Attachment 403624
    are you using Mach3 ?
    the BOB has 5 inputs
    you can connect a normally closed E-stop switch between the input GND/ VSS and an input (eg pin 10)
    what type of limit switches do you have ?
    if you have two micro switches per axis
    you can wire them all as normally closed switches in series
    connected between the input GND / VSS and an input (eg pin11)
    the advantage of using N/C switches instead of normally open switches in parallel
    is N/C switches fails safe if a wire breaks
    with N/O switches you will not know the wiring has a break and the limit switches will not work
    this saves 3 of the 5 inputs for other uses such as a touch probe to gauge the tool length
    with Mach3
    one of the limit switches on each axis can double up as a home switch
    John
    Dec 2009
    36
    Yes my BOB looks like that. I don't use switches on any of the axis I found it to be a bother. I would use the touch probe to gauge tool length. I didn't see the VSS you are talking about, mine has VDD marking on the board. Is that the same? I'm using Mach 3. Do you know anything about the switches on the drivers? They are the DM 542A.
    Mar 2007
    2083
    breakout boards from different suppliers are marked slightly differently
    the more noticeable thing is the two 5v supplies to the PC and machine sides of the BOB
    some boards have 2 pairs of +5V and GND terminals and others have +5V & GND and VDD & VSS
    the diagram in post 2 is reverse engineered from several photos found online
    the VDD is high lighted here
    Attachment 403662
    I have not used the DM 542A.
    this PDF manual shows on pages 11 & 12 details of the DIP switches
Name:	Leadshine DM542.pdf
ID:	403664Click image for larger version.
    switches 1 to 3 set the motor current
    switches 5 to 7 set the number of micro steps
    John
  1. Has anyone bought from Changzhou Longs-Motor?
    By MrArmyAnt in forum Waterjet General Topics
    Last Post: 10-06-2018, 09:40 PM
  2. Nema23 stepper motor 425oz.in 23HS9430B Longs motor
    By tager_rot in forum For Sale Only
    Last Post: 02-03-2016, 05:33 AM
  3. Longs Motor From China---Cherry
    By longs_motor in forum Waterjet General Topics
    Last Post: 08-18-2015, 06:29 AM
  4. Slow speeds with Longs motor kit
    By Streetslab in forum Stepper Motors / Drives
    Last Post: 04-09-2015, 02:45 PM
  5. Help with 878oz Kit from Longs Motor?
    By allengambrell in forum Stepper Motors / Drives
    Last Post: 03-27-2012, 04:16 AM
