585,573 active members*
3,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Memory Upgrade Options
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Aug 2011
    419
    Re: Memory Upgrade Options
    Yes, but this jewels in the a weak safe.
    "Imagination is more important than knowledge."
  2. #22
    Mar 2018
    65
    Quote Originally Posted by OkumaWiz View Post
    When adding the floppy drives, the capacity is 1.44mb from each virtual FD, but the schedule program can access all of them up to 99 in a schedule program so it would give you roughly 138mb max file size limit of 99 1.44 mb sections.
    PSELECT FD0:A1.MIN,,,Q1
    PSELECT FD1:A2.MIN,,,Q1
    PSELECT FD2:A3.MIN,,,Q1
    PSELECT FD99: A100.MIN,,,Q1
    END
    Not the easiest way to do it, but probably the least expensive way to get over 100mb to run on your machine.
    That's really cool, I didn't think it would be able to do that. Definitely something to try out. At this point I have more time than money.
    Now I'm wondering, how does it handle mid program restarts?
    Thank you to the knowledge of the hive-mind.
    Dave
  3. #23
    Mar 2018
    65
    PS: I'll be driving through your neighborhood tomorrow afternoon on my way to the motor city.
    Tried to send you a PM, but it failed.
    Dave
  4. #24
    Apr 2009
    1262
    If you interrupt the running program by reset, it will want to start running the active program over from the beginning. It would be possible to restart within the program the same as any other program.
    Pm probably full again. The zone stinks as far as pm storage goes.
    Best regards,
    - - - Updated - - -
    Quote Originally Posted by kurmay View Post
    And you are the locksmith?
    Experience is what you get just after you needed it.
  5. #25
    Aug 2011
    419
    No, I am an engineer.
  6. #26
    Mar 2018
    65
    [QUOTE=OkumaWiz;2230866
    And you are the locksmith?[/QUOTE]
    At least you didn't ask for the Keymaster or the Gatekeeper...
    Thank you all again, I am sure I will have more questions soon.
    Dave
  7. #27
    Mar 2017
    314
    why are there so many Okuma users in Antarctica? Did you move the machines in on Dog Sled?
    How many Dogs does it take to drag a MX45VAe?
  8. #28
    Jun 2015
    4154
    hy general, stay in school, eat actual food, get a job, a house, she has 2-3 kids, and one lives long after retirement
    dogs are running in the snow, after a big mx45vae
    it's a metaphor for freeland / kindly
  9. #29
    Apr 2011
    112
    Quote Originally Posted by countryguy828 View Post
    And another thought just to satisfy my curiosity...
    If a guy adds another memory card into the machine what happens? I can think of 3 possibilities. A) nothing, nothing will happen unless software is updated. B) the memory becomes available to MD0:, without a software change. C)the memory shows up in MD1:, without a software change.
    How is the software changed? Is it a parameter in the machine? or a parameter in the software that loads on bootup?Attachment 410792
    I guess its a trade secret Okuma is keeping under wraps.
    Dave
    I have tested this way with a 16mb CMOS . It works with large Sram and Dram but not a larger flash drive . My originaly was 8mb and i pun 16mb . It was foramting the memory , i made a extended install , a MD instal , then on the FR instal it was giving a a 152 error
    Change the memory board or flash memory card causing the error. * Correct the control software (in the case of task running). From the image i have seen it checks a file from size . I dont know if we can open a system disk and write the size of the new cmos. Dont know how to open the disks.
  10. #30
    Mar 2018
    65
    OK Guys I finally got back to this project. Lots of other stuff was in the way.
    I thought of a couple more questions...
    Does the floppy disk need to be OSP formatted for this scheduling to work or is DOS ok?
    Could the scheduling be configured to work over the rs-232 PIP connection? Seems I came across a DNC software somewhere that said it could break the code down into sections automatically and was trying to figure out how that would work.
    Thanks again for all of your advice guys,
    Dave in Ohio
    The correct answer is A. Memory is defined by Spec code, so only software change from Okuma will recognize more hardware. Yes Okuma protects their jewels...kurmay? Enlighten us?
    END
    Best regards,
  11. #31
    Mar 2018
    65
    Just a quick update to this... I am currently at the belief that having a schedule program point to the floppy is not possible. Pleas see my other post at https://www.cnczone.com/forums/okuma...ons-solve.html for more information. IF someone has been successful at getting this to work I definately want to know how or what you did to get it to work.
    Dave in Ohio
  12. #32
    Apr 2022
    May I have a detailed program example? Please write for me to look at one program.
    1. The main program loaded into the machine MD1:
    2. The 2nd program that the device uses in the floppy disk FD0:
    3. The 3rd program that the device calls used in the floppy disk. FD0:
    4. The 4th program that the machine uses in the floppy disk FD0:
    Ask for an example of a drilling program.
    thank you
Page 2 of 2 12
  1. VMC 760/22 - PC upgrade options?
    By hank.sd in forum Bridgeport / Hardinge Mills
    Last Post: 05-09-2012, 05:45 PM
  2. 16M memory upgrade
    By 1ctoolfool in forum Haas Mills
    Last Post: 04-26-2010, 12:32 PM
  3. memory upgrade
    By conklin36 in forum Controller & Computer Solutions
    Last Post: 02-07-2010, 05:04 PM
  4. fanuc 16m external memory options
    By ihranrp in forum Controller & Computer Solutions
    Last Post: 08-18-2009, 06:00 PM
  5. HAAS memory options?
    By panaceabea in forum Haas Mills
    Last Post: 07-08-2009, 04:26 AM
