Yes, but this jewels in the a weak safe.
"Imagination is more important than knowledge."
If you interrupt the running program by reset, it will want to start running the active program over from the beginning. It would be possible to restart within the program the same as any other program.
Pm probably full again. The zone stinks as far as pm storage goes.
Best regards,
- - - Updated - - -
And you are the locksmith?
Experience is what you get just after you needed it.
No, I am an engineer.
[QUOTE=OkumaWiz;2230866
And you are the locksmith?[/QUOTE]
At least you didn't ask for the Keymaster or the Gatekeeper...
Thank you all again, I am sure I will have more questions soon.
Dave
why are there so many Okuma users in Antarctica? Did you move the machines in on Dog Sled?
How many Dogs does it take to drag a MX45VAe?
hy general, stay in school, eat actual food, get a job, a house, she has 2-3 kids, and one lives long after retirement
dogs are running in the snow, after a big mx45vae
it's a metaphor for freeland / kindly
I have tested this way with a 16mb CMOS . It works with large Sram and Dram but not a larger flash drive . My originaly was 8mb and i pun 16mb . It was foramting the memory , i made a extended install , a MD instal , then on the FR instal it was giving a a 152 error
Change the memory board or flash memory card causing the error. * Correct the control software (in the case of task running). From the image i have seen it checks a file from size . I dont know if we can open a system disk and write the size of the new cmos. Dont know how to open the disks.
OK Guys I finally got back to this project. Lots of other stuff was in the way.
I thought of a couple more questions...
Does the floppy disk need to be OSP formatted for this scheduling to work or is DOS ok?
Could the scheduling be configured to work over the rs-232 PIP connection? Seems I came across a DNC software somewhere that said it could break the code down into sections automatically and was trying to figure out how that would work.
Thanks again for all of your advice guys,
Dave in Ohio
Just a quick update to this... I am currently at the belief that having a schedule program point to the floppy is not possible. Pleas see my other post at https://www.cnczone.com/forums/okuma...ons-solve.html for more information. IF someone has been successful at getting this to work I definately want to know how or what you did to get it to work.
Dave in Ohio
May I have a detailed program example? Please write for me to look at one program.
1. The main program loaded into the machine MD1:
2. The 2nd program that the device uses in the floppy disk FD0:
3. The 3rd program that the device calls used in the floppy disk. FD0:
4. The 4th program that the machine uses in the floppy disk FD0:
Ask for an example of a drilling program.
thank you
