585,717 active members*
3,814 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Thickness of aluminum plate for Z axis slide
Results 1 to 6 of 6
    Mar 2016
    3
    Is 1/4 aluminum thick/rigid enough for my z axis plates.
    35538
    Re: Thickness of aluminum plate for Z axis slide
    Depends on the overall design of the machine, but generally, I'd say no. Mose people use 1/2" to 3/4", or even 1" on larger machines.
    Oct 2005
    73
    I'm going 10mm on mine because it's what I have available, and I'll be putting 6mm stiffener plates on the sides to increase rigidity. I'm expecting it to be alright because the FEA software says it will actually be more rigid than a solid 16mm plate, but I'm prepared to have to upgrade it at a later date if it's not suitable.
    As for a 6mm plate with no reinforcement I'd echo Gerry, probably not OK.
    May 2005
    3920
    I wouldn’t go that thin even on a PCB engraver.
    Jan 2008
    1528
    Quote Originally Posted by jones View Post
    This is the best approach. Flat plates are flimsy.
    May 2005
    3920
    Quote Originally Posted by pippin88 View Post
    Also you can find Aluminum channel extrusions or even steel channel that would reduce the machining and assembly effort. It might take a bit of looking because you will need to find something wide enough in the drops section of your metals supplier or pay through the nose for a piece of prime cut to length. Cutting off the flanges from an H beam is also a possibility.
    I just wanted to point out that there are multiple ways to address the flat plate problem. Most of these will help keep the weight down compared to a flat plate thick enough to give similar performance.
    Also the amount of unsupportted extension is a factor. Even the spindle mount can effectively stiffen the mounting plate. In general though 6 mm is thin for most routers.
  1. Thickness of Aluminium plate for gantry?
    By prestondocks in forum Mechanical Calculations/Engineering Design
    Last Post: 12-09-2018, 04:03 PM
  2. ball screw mounting plate thickness
    By jschoch in forum Linear and Rotary Motion
    Last Post: 06-23-2018, 07:02 PM
  3. Surfacing aluminum plate, for tooling plate
    By 30dayo in forum Material Machining Solutions
    Last Post: 12-21-2013, 11:29 PM
  4. Granite surface plate thickness accuracy?
    By offabit2001 in forum MetalWork Discussion
    Last Post: 08-18-2010, 01:24 AM
  5. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
