584,866 active members*
5,083 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > fadal vmc 15 - Error #9
Results 1 to 7 of 7
    Aug 2010
    33
    Hi there,
    The machine is:
    Fadal VMC-15
    Model #: 914-15
    Year of mfg: 1997
    Spindle motor: Baldor 10HP, 3ph
    Spec.: 37F71800073 X073 X173
    Frame: 215TC,
    Volts: 230/460
    Baldor H2 Vector Drive purchased new in Oct. 2010.
    I just fixed the X axis problem. It was a bad new axis amplifier. I bought from another source
    and all the axis X, Y and Z now work.
    Machine was not used for about 14 days.
    I was going to start a new job.
    I CS the machine – Success.
    Then pressed the START – Success.
    Entered MD – Success.
    Because the machine did not work on the high speed range (for 5 years), I Issued S1500 and pressed START
    to make sure that the machine is on the low range of speeds. - Success.
    Issued M3 then pressed ENTER to start the spindle – Faliure:
    Got the messages:
    “EMERGENCY STOP – TAKE APPROPRIATE ACTION
    C AXIS FAULT(S) AS FOLLOWS:
    ERROR NUMBER #9
    SPINDLE FAULT LINE.”
    Whats going on?
    How to troubleshoot?
    Did just my vector drive took nosedive?
    Feb 2013
    89
    Re: fadal vmc 15 - Error #9
    When this happened to me, like a noob, I didn’t have the air turned on and the air cylinder didn’t engage the drive belt and faulted the machine. I believe when you turn the machine on, one of the hi or low speed cylinders should automatically engage the belt before you even CS the machine. I would have to roll out of my bed and go to the garage to double check this. I can check in the morning though.
    Apr 2014
    344
    Quote Originally Posted by NismoGT View Post
    Because he has a vmc 15 I’m going to guess that it has a 7500rpm spindle that doesn’t care if the air is on.
    14 days ago did the everything work fine?
    Feb 2013
    89
    Quote Originally Posted by ianagos View Post
    Is this question directed at me?
    Aug 2010
    33
    You right. My spindle would work without any air.
    Feb 2007
    171
    Sir,
    It sounds like you have an issue with the fault line on your inverter. This is an internal failure within the drive itself. Like mentioned before, check to make sure your belts are good and they engage in both high and low range. You will need to contact ITS where the inverter was purchased and ask where the fault line is going into the drive. From there you can see if the 24VDC is pulled to ground, thus the alarm. Otherwise you are looking at a new inverter. We stock them all.
    Let me know how this turns out and I will help as I can.
    FadalCNC Tech Support
    Apr 2014
    344
    No it was directed at the op.
  1. fadal 4020 error #17
    By jack123529 in forum Fadal
    Last Post: 12-08-2017, 07:08 AM
  2. Fadal vmc 15 Memory error
    By Daniel Boone in forum Fadal
    Last Post: 01-14-2015, 02:34 AM
  3. Fadal error#31
    By hamuna in forum Fadal
    Last Post: 10-24-2014, 12:35 PM
  4. Fadal VMC 15 error parameter error
    By jerodor in forum Fanuc
    Last Post: 06-12-2014, 05:22 AM
  5. Fadal error codes
    By HareBall in forum Fadal
    Last Post: 01-22-2005, 02:52 PM
