585,997 active members*
4,784 visitors online*
Results 1 to 6 of 6
    Oct 2018
    5
    Mori Seiki TV 300 Meldas MSC 802M
    Hi, I have just purchased Mori Seiki TV300 with Mitsubishi MELDAS MSC802M controller, model 2001-2. All machine parameters and book are with it. These machines were imported from Japan. When I powered the machine its screen shows Japanese language. So I need help, how I could change the screen language. I would appreciate if I get some help.
    Oct 2018
    Dear Awan67!
    You can change language to English by setting Parameter #1043=1.
    1. The first, you put to GOP softkey, and press to unlock
    2. Then, press OFFSET softkey 2 times.
    3. Select SETUP softkey (the 5nd), then press INPUT key
    4. select Y symbol.
    5. You search the parameter #1043, input 1 to Data blank and press INPUT softkey.
    Oct 2018
    5
    Hi, thank you for your assistance. I have tried as your instruction but i am unable to reach your 3rd step (set up soft key 2 time)
    I would appreciate if you could assist me if possible by a short vdo?
    I have the picture of the screen to show you but i am unable to find how to upload these.....
    Hope to get your reply. my alternate email is [email protected].
    Thank you
    Oct 2018
    5
    Quote Originally Posted by lediepanh View Post
    Dear Awan67!
    4. select Y symbol.
    I am attaching the screen pictures for your better understanding.
    Attached Thumbnails Attached Thumbnails 20181123_190349.jpg   20181123_185423.jpg   20181123_185344.jpg
    Oct 2018
    5
    Dear Awan67!
    4. select Y symbol.
    Hi, I got some difficulty to remove some inter locking's in the machine, Anyhow I have followed your instructions and successfully reached #1043 and changed it to 1(english). Turned off the machine and restarted and found that the screen still shows some Japanese language specially on the top side of the screen. On the bottom it is English language.
    I have successfully homed all axis tool is indexing but i am unable to run the spindle and unable find the screen to write my program.
    I hope you would assist me.
    Thank You
    Regards,
    Arshad
    Nov 2010
    22
    Re: Mori Seiki TV 300 Meldas MSC 802M
    Quote Originally Posted by Awan67 View Post
    Thank You
    Regards,
    Arshad
    I can help change Japanese to English...
    go to GOP, turn off the keys, push down arrow until 20 is displayed, change it to a 1, then power cycle the front panel.
  1. Mori Seiki TV-30 MSC-802M (M50) interpolation problems
    By Custom Billet in forum Mori Seiki Mills
    Last Post: 04-19-2017, 04:08 PM
  2. Backup Mori Seiki NL2500 (Mitsubishi Meldas)
    By Krynio in forum Mori Seiki Software
    Last Post: 08-27-2015, 07:04 PM
  3. Coordinate rotation problem on MORI SEIKI TV40 MSC-802m
    By kpandy in forum MetalWork Discussion
    Last Post: 08-28-2014, 04:25 PM
  4. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  5. Mori TV-300 MSC-802M control
    By toe-peg in forum Mori Seiki Mills
    Last Post: 02-04-2011, 08:20 PM
